Toilet Seat In Crooked Position - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2014, 10:43 AM   #1
Rewards Points: 578
Toilet seat in crooked position
I recently bought a condo. Since the toilet seat was damaged and also in a crooked position (about 1" more on the left side, but 1" short on the right side), I bought a new toilet seat to replace it.
After I installed the new toilet seat, I found it is still in a similar crooked position. See attached photos.
After examination, I've found that the two anchors (holes) to connect the seat are not in a symmetric position. The left one is closer to the water tank compared to the right one.
I contacted the manuafaturer of the toilet, Crane Plumbing. They told me since I was not the originial purchaser of the toilet, there is not warranty coverage for this toilet.
What are my options without reinstalling a new toilet?
Toilet seat in crooked position-img_1199.jpg   Toilet seat in crooked position-img_1202.jpg
HomeLearner is offline   Reply With Quote
Old 10-23-2014, 11:23 AM   #2
Rewards Points: 298
Loosen nuts. Adjust seat,tighten nuts while holding seat in place.
flhtcu is offline   Reply With Quote
Old 10-23-2014, 11:25 AM   #3
Rewards Points: 578
Will try what you suggest.
The Following User Says Thank You to HomeLearner For This Useful Post:
rjniles (10-24-2014)
Old 10-23-2014, 06:27 PM   #4
Rewards Points: 578
When I re-positioned the seat and tightened the nuts, the left nut split the plastic parts, causing the cap unable to close. As a result, the seat lid won't close. See photos.
I'm also concerned that screwing the nuts all the way in may damage the plastic parts (because they would split apart).
Old 10-23-2014, 09:15 PM   #5
Super Moderator
Gymschu's Avatar
Rewards Points: 514
Any big box store has replacement plastic parts. Redo it but don't OVERTIGHTEN.
Old 10-23-2014, 09:27 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 186
I moved thread to plumbing.
What you have is a cheap plastic seat. Best to replace it with a good quality wood one from a company like Bemis or Church.
Old 10-23-2014, 10:11 PM   #7
Rewards Points: 578
The seat I got is Kohler brand. Cost me about $42.
Will a wood one allow me to adjust the angle of the seat (without breaking anything)?
Old 10-23-2014, 10:13 PM   #8
Rewards Points: 578
I may not know how to replace the plastic parts even if I get the right parts.
Old 10-24-2014, 03:08 AM   #9
Rewards Points: 288
Many of the toilet seats that I've seen come with two sets of metal washers. One set with center holes and one with offset holes. You may be able to take up the difference in your out of place holes by using the offset washer on one side and the centered washer on the other. Or if it's really bad, use the offset washers on both side opposite of each other.
BlackTiger is offline   Reply With Quote
Old 10-24-2014, 05:32 AM   #10
Rewards Points: 5,666
I could build you a crooked wooden seat to match the crooked holes, but OH My, if you thought plumbers were expensive you should see the bill for one of those little fellers. My wife is still paying for this one 9 years later.
Old 10-24-2014, 08:58 AM   #11
Rewards Points: 3,230
It looks like you have one of those no slam toilet seats, they are designed for a quick disconnect. It's made so you can slide the toilet seat right out for easy cleaning then slide it back in. They do cost about 40-50 dollars. They been on the market for awhile now, you either love them or you don't. Good for families with little ones, etc.
It may not be broken, just back off the bolts a little, re-adjust seat so it's even, tighten back down snug, do not overtightened. It's design to slip in and out of place without removing the bolts for easy cleaning.
As e plumber suggested, you may want to opt for a good typical toilet seat if that one is broken. Just a suggestion.
jmon is offline   Reply With Quote
Old 10-27-2014, 09:23 PM   #12
Rewards Points: 136
From the pics you posted, Home learner, the plus sign on the black tab at the mounting bolt tells me there is an adjustment capability with that particular seat. Even though I have not seen that exact style myself, I would take the seat off and just play with it like I would trying to put a jigsaw puzzle together. See if and how many diff ways to configure the components to make it fit. Like I said though, thats just a guess.
karin els is offline   Reply With Quote
Old 10-27-2014, 09:41 PM   #13
Rewards Points: 578
I do not see two sets of holes that come with the seat.
Old 10-28-2014, 04:23 PM   #14
Rewards Points: 136
Are the nuts on the bottom holding the seat on right? Most have a beveld side and then a flat side with a leg off to the side to catch the side of the bowl when tightening. I would make sure the beveled side is up as to help center the seat in the holes.
Old 10-29-2014, 03:41 PM   #15
Rewards Points: 578
The left and the right side seem identical. See photos.
Toilet seat in crooked position-leftnut.jpg   Toilet seat in crooked position-rightnut.jpg
Sel clogging toilet (no one used for weeks) Patrick DuBois General DIY Discussions 8 02-23-2014 06:11 PM
How easy is it to find replacement toilet of same profile/size daluu Plumbing 16 10-27-2013 05:56 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
