Toilet Rough-In - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By chandler48
  • 1 Post By MTN REMODEL LLC
Old 03-04-2018, 06:13 AM   #1
Rewards Points: 106
Toilet Rough-In
I am replacing my toilet and when measuring from the wall to the center of the flange bolts it is exactly 13". There is about a a 1" gap from the top of the tank to the wall.
Any ideas as to why it is 13" and not 12"?
Is a standard 12" toilet going to work? And will it be 1" further away from the wall?
cjenkins08 is offline   Reply With Quote
Old 03-04-2018, 06:21 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,570
Re: Toilet Rough-In
Won't be a problem. That is far better than having it 11" from the finished wall The one inch will keep the tank from hitting the wall.
SeniorSitizen likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-04-2018, 06:56 AM   #3
Rewards Points: 6,430
Re: Toilet Rough-In
If the toilet is ever replaced you may appreciate that extra distance.
Old 03-04-2018, 07:08 AM   #4
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Toilet Rough-In
either your home is older 14" rough-in & extra wall thickness was added to
or there is a structural issue that prevented allowing the toilet flange to be closer to wall... or that gap was for future wall thickness allowances.
I've seen some newer toilets that would not even allow for shoe mold at base so all & all you have a good problem compared to what it could be IMO
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 03-04-2018, 08:56 AM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,854
Re: Toilet Rough-In
Yes..... Might have been intentional forsight... some people will tile a bath wall.
chandler48 likes this.
MTN REMODEL LLC is offline   Reply With Quote
Mini-project: Rebuilt my toilet. First time doing it. r0ckstarr Project Showcase 6 05-13-2014 02:59 PM
10 inch rough in, 1.28 gpf, one-piece toilet takingtoolong Plumbing 13 05-06-2014 06:10 AM
Toilet rough in size 14in or 12in? rkj Plumbing 12 02-24-2014 09:30 AM
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 01:39 PM
Toilet rough in dilema facial Plumbing 3 01-11-2010 04:04 PM
