Toilet Rim Holes Not Working - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-22-2016, 02:40 PM   #1
Toilet rim holes not working
Hoping for a solution to an apparently unusual toilet problem. We just moved into an older home. The master bath has a newer looking 1.6g Toto unibody toilet.
The problem is similar to this one I found:
http://www.diychatroom.com/f7/toilet...9570?_k=rz7wjs
Although I don't see any build up I still tried cleaning the holes with a coat hanger and a Muriatic acid soak without success.
I was at a loss. The siphon jet works fine, the toilet flushes. But nothing out of the rim. Out of curiosity I plugged the siphon jet and the rim holes worked perfectly! Unrestricted, full force, they all worked perfectly.
Problem solved I thought for a second until I unplugged the siphon jet. Nothing through the rim again!
The fill mechanism has been replaced with a Korky but the flapper and down spout look original.
Unlike the other thread, this is a unibody so there are no holes to be blocked. What could the issue be?
Thanks in advance,
-Steve
Sdpluth is offline   Reply With Quote
Old 10-22-2016, 03:51 PM   #2
JUSTA MEMBER
Rewards Points: 3,122
Re: Toilet rim holes not working
Put a little food coloring in to the tank, enough to color the water.
Then flush and observe if any color comes out the rim holes.
Many toilets only have enough water coming from the rim to trickle. And is very hard to see, so color the water and test.
ED
de-nagorg is offline   Reply With Quote
Old 10-22-2016, 04:15 PM   #3
I had already done that test. Nothing comes out the rim unless the siphon is blocked. Then it comes out the rim perfectly.
The Following User Says Thank You to Sdpluth For This Useful Post:
de-nagorg (10-22-2016)
Old 10-22-2016, 07:15 PM   #4
Rewards Points: 3,258
Does the flapper have a fin or flap on the underside that partially obstructs the flow out of the tank down into the bowl?
Lift up the flapper and look down the hole below. Any foreign objects down inside?
Try adding a little water to the bowl before a flush. Do the rim holes work better or worse depending on the level of water in the bowl?
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 10-24-2016, 01:23 PM   #5
Thanks for the suggestions. I haven't checked the flapper yet. I did slowly fill the bowl until I heard water tricking over the trap. When I flushed there was no change. Still no water out of the rim holes.
Toilet Flushing Issues Chrishwa Plumbing 3 08-04-2012 12:13 AM
Toilet Anchor Bolt Holes missing? watts up? Plumbing 7 03-23-2012 06:36 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Holes in flange dont match holes in toilet! ljenkins Plumbing 2 02-06-2010 07:17 AM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
