Toilet Rim Holes Not Working - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-23-2014, 05:08 PM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Originally Posted by silence View Post
Apologies for bumping an old post. Was there any resolution to this issue? I'm experiencing the exact same problem as the original poster.
Why wouldn't you guys call Kohler first thing?
XXX
Old 12-23-2014, 05:16 PM   #17
Rewards Points: 4
I'm communicating with them. So far they've told me to ream out the holes and check the tube in the tank. Just curious if OP happen to find the solution.
silence is offline   Reply With Quote
Old 12-23-2014, 05:30 PM   #18
Rewards Points: 2,016
Defective casting. Replace.
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (12-23-2014)
Old 09-07-2015, 01:17 PM   #19
Rewards Points: 2
I just used a KORKY replacement kit to replace the parts inside the tank. The rim jets did not work after this replacement. I found that the replacement gasket that the tank sits on was smaller than the previous, and was sitting lower inside the opening, blocking the two holes that lead to the rim jets. I took an exacto knife and cut holes at the base of the gasket to match up with the stream jet holes. Problem solved. Working great.
DIYBTRON is offline   Reply With Quote
The Following User Says Thank You to DIYBTRON For This Useful Post:
deltadon (03-21-2016)
Old 03-21-2016, 02:46 PM   #20
Rewards Points: 6
Re: Toilet Rim holes not working
I was experiencing this same problem with my Kohler toilet. I read through all the posts and found the last one by DIYBTRON. I removed the tank and sure enough the plastic threaded tube and rubber gasket were blocking the fill holes for the rim jets. I cut through the rubber with a sharp knife and then drilled two 1\2 holes in the plastic down spout part and voila, water now flowing from jets.
deltadon is offline   Reply With Quote
Old 12-19-2016, 12:59 PM   #21
Rewards Points: 2
Hey guys, so this is my first time ever posting to a blog but Ive just gotten so frustrated with my Kholer toilet and was having the hardest time even figuring out what to type in my google search to find the name to my problem so thank you all for posting. i now know the name of my problem and it is the issue with my toilet rim holes not flushing at all just a dry waterless attempt when i flush it. My siphon jet works just fine. I'm going to try and do all the suggestions mentioned in this post but if anyone has had any luck with Kholer or found a solution i would be greatly in your debt for it. Wish me luck! ill be checking back in by the end of the week for updates or to see if anyone has any solutions. Thanks!
IAMNOT is offline   Reply With Quote
Old 01-02-2018, 03:13 PM   #22
Rewards Points: 2
I just made an account to answer this question. My Kohler has had extremely poor flow to the rim holes, and I have been scouring for answers to no avail. I have finally found the solution (for me at least) and it is annoyingly simple. I found out that my toilet flushed just fine without the tank lid on, but poorly with it on. This was driving me nuts until I found out that the lid has a hole in the back and in the bottom so that when the water flushes, air travels through the lid to fill the void. My lid was tight against my wall which was blocking air flow to the tank, so that when the toilet flushed, the water did not go up the hose and into the rim holes easily. I repositioned the tank lid so that the hole in the back was not obstructed and voila, toilet flushes perfectly. Crazy.
Hope this helps others that may be having the same issue.
gnarkilleptic is offline   Reply With Quote
Old 03-15-2019, 01:38 AM   #23
I had to sign up just to thank DIYBTRON for the info! I had my suspicions this was an issue, but wasn't sure. Really surprised by the lack of Google results about this issue, considering a common home Depot replacement with a common Kohler toilet has this compatibility issue... Not looking forward to separating my tank and bowl again 😑
tayeke is offline   Reply With Quote
Old 03-15-2019, 09:05 PM   #24
Rewards Points: 1,982
The orig poster theorized a manufacturing error......in which case, unless he just installed it, it NEVER would have worked. I was having flushing problems also.....and just spent like two hundred bucks on a new American standard cadet 3 chair height extended bowl. Easy install, flushes fast and well, no worries. Ron
ront02769 is offline   Reply With Quote
Tags
flushing , rim holes , toilet
Creating a working space helpinggirl General DIY Discussions 10 11-14-2012 08:18 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Where to Move this Toilet? estburke Plumbing 8 10-10-2010 11:52 PM
