Toilet Level Drains After Flushing - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-04-2016, 01:54 AM   #1
Rewards Points: 34
Toilet level drains after flushing
After flushing the toilet the water level drains almost empty. It always stop at the same level, and when it gets to that point it makes a short hissing sound for a couple seconds. When the water is that low the next flush doesnt actually flush. Rather it gurgles a bunch of air up. The toilet will refill and less than a couple minutes its back to where it was.
Ive attached a pic of where the water stops everytime.
2 bathroom house, no other plumbing issues.
Robert95z is offline   Reply With Quote
Old 11-04-2016, 05:08 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,682
Re: Toilet level drains after flushing
Sounds like it's siphoning out. It stops when an air gap is created and you hear the hissing.
Is this a new problem?
Is there a vent line attached to the drain line?
123pugsy is offline   Reply With Quote
Old 11-04-2016, 05:12 AM   #3
Rewards Points: 34
The problem has occurred in the past. And it seemed to fix itself. It's back and been around for awhile now.
There are a couple vents on the roof near the toilet. In close proximity of the toilet is 2 sinks, a shower, and a tub. So not sure what vent goes to what.
Old 11-04-2016, 06:40 AM   #4
JUSTA MEMBER
Rewards Points: 3,308
Look upon the roof and see if you have a birds nest built on the vent lines.
Something is plugging the vent, so that the flush continues to siphon the water after it's finished.
Maybe the flush mechanism is not filling the bowl properly, but it sounds more like a poor vent problem.
ED
de-nagorg is online now   Reply With Quote
Old 11-04-2016, 03:57 PM   #5
Rewards Points: 1,866
Make sure the water level in your toilet tank is where it is supposed to be.
Old 11-05-2016, 01:23 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
get a pale and slowly fill the bowl to its level slowly so you don't create a vacuum mark it and wait make sure one is using water any ware in the house if it drains out you've got a bad toilet if not look for venting issues.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 11-06-2016, 11:45 PM   #7
Rewards Points: 38
You do not have venting issues affecting your toilet. You have a common partial clog, that's it. Use a plunger or toilet auger to clear. If that fails, remove toilet and check for obstructions in toilet trap.
SHR Plumber is offline   Reply With Quote
Old 11-07-2016, 07:25 AM   #8
hkstroud's Avatar
Rewards Points: 6,684
I agree. However I don't think it is in the toilet trap. I think it is in the toilet arm before the vent. When you flush the second time, the second flush water pushes air in the pipe back up and out the toilet bowl.
Pull toilet and snake. Easy snake job.
hkstroud is offline   Reply With Quote
weak flushing toilet 8Jack8 Plumbing 7 10-22-2014 05:15 PM
toilet gurgle when flushing - long post aribert Plumbing 1 07-01-2013 05:10 PM
Toilet Flushing Issues Chrishwa Plumbing 3 08-04-2012 12:13 AM
Toilet backfill after flushing hohadcr Plumbing 6 12-20-2009 04:01 PM
Water level in toilet bowl Kath Plumbing 10 06-22-2006 03:26 PM
