Toilet Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2015, 09:21 AM   #16
Rewards Points: 180
Thanks mj12. The toilet had a jumbo ring on it and when I took it off it was apparent that it was too short to make a proper seal. Would you stack two rings?
jwiens is offline   Reply With Quote
Old 02-01-2015, 12:34 PM   #17
Rewards Points: 1,926
Yes.. 2 rings are fine. Make sure they are at house temp prior to using.
The Following User Says Thank You to Ghostmaker For This Useful Post:
mj12 (02-01-2015)
Old 02-01-2015, 01:08 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 240
1st post shows what appears to be the left over plastic flange from the old wax
This might account for the 2.5" measurement- got to remove that piece.
Personally, I try not to stack waxes. I was taught years ago not to.
I'd rather use flange extensions. But to each his own....
Intermittent Toilet Mystery Leak bills_diy Plumbing 6 04-07-2018 09:20 PM
Toilet (Mansfield) Ghost Leak golddog Plumbing 6 10-25-2012 07:10 PM
Wax Ring Replacment and Toilet Leak kennykenny Plumbing 4 11-27-2010 02:43 PM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 06:52 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
