Toilet That Isn't Used Hardly At All That Has This Black Mold-ish Residue In The Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2015, 08:49 AM   #1
Rewards Points: 222
Toilet that isn't used hardly at all that has this black mold-ish residue in the tank
We have this bonus room toilet that doesn't get used very often (maybe 4-5 times a month) that has this black mold like residue inside the upper tank.
Is this something that is always going to come back after I clean it up just because it sits there unused?
imola ghost is offline   Reply With Quote
Old 11-21-2015, 09:13 AM   #2
Rewards Points: 18,760
Most likely.
A simple flush more often will go a long way to prevent it.
Dropping in one of those blue toilet cleaning blocks may also help.
Nik333 (11-25-2015)
Old 11-24-2015, 04:23 PM   #3
Could be iron of t you are on a well
gassyplumber is offline   Reply With Quote
Old 11-24-2015, 08:42 PM   #4
Rewards Points: 5,348
How does iron create mold?
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
joecaption (11-25-2015)
Old 11-25-2015, 01:13 AM   #5
Rewards Points: 4,702
This happened to me in a toilet tank that was in a room with poor ventilation ( the outside vent ran but was mostly stuccoed over). It looked like someone had stuffed black bunny rabbits in the tank. The mold even flowed over the tank. The room had been unused for at least 3 mths. I blasted it with chlorine bleach which was a mistake for me as I am sensitive to bleach and the ventilation was poor. I didn't know that at the time. joecaption's option seems more reasonable. If that doesn't work, try the chlorine bleach in the tank. The CDC states the people most sensitive to black mold are those with allergic asthma. My room had a shower which added more moisture. Since mold spreads by spores, it might be something to look for in the rest of the house. I think gassyplumber meant an iron stain?
Nik333 is offline   Reply With Quote
Old 11-25-2015, 01:19 AM   #6
Found this also : http://extension.psu.edu/natural-res.../iron-bacteria
Old 11-25-2015, 07:05 AM   #7
Rewards Points: 1,248
Could also be the rubber from the gaskets. Depending on its age, they should be replaced.
carpdad is offline   Reply With Quote
Old 11-25-2015, 05:25 PM   #8
Rewards Points: 1,848
Drop a chlorine toilet tank tab in the tank. Heck I get that during the summer from Cleveland water.
Ghostmaker is online now   Reply With Quote
How to control Mold Part 1 Maintenance 6 How To Guides 18 05-01-2017 09:17 AM
Toilet leak between toilet bowl and tank - ONLY when flushing Mike.neace Plumbing 10 11-11-2014 12:28 PM
Removing anti-siphon valve from a toilet tank Chris0516 Plumbing 7 09-30-2012 05:09 PM
Water draining into toilet bowl but not from tank black00 Plumbing 6 09-19-2012 08:28 PM
Black in my toilet tank Tabatha295 Plumbing 2 10-15-2011 11:29 PM
