Toilet Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2015, 09:50 PM   #16
Rewards Points: 1,952
"Ghost.... I got a little confused here....assuming there is no wet/drainage above the toilet install.... can not the main stack function as the vent...????"
Since he was installing the toilet in the basement and looking at the picture and seeing a Clean out I immediately knew he was cutting into a waste stack for the new install.
So to answer your question if nothing is draining down the stack from floors above then it is a vent and a toilet would be vented. But since the upper floor or floors was draining down the stack it is a waste stack and is not considered a vent.
The Following User Says Thank You to Ghostmaker For This Useful Post:
MTN REMODEL LLC (05-02-2015)
Old 05-01-2015, 11:21 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 302
TIA
Best
If there is no wet/drainage (as you refer to it) above the toilet then it's not a main stack- it is a vent.
UPC allows limited wet venting for 6 vertical feet and the fixtures must be on the same floor. Also, only 1dfu or 2 dfu fixtures are allowed to discharge into the wet section. Maximum amount of fixtures is 4
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (05-02-2015), MTN REMODEL LLC (05-02-2015)
Old 05-03-2015, 10:17 PM   #18
analogmusicman's Avatar
Rewards Points: 560
right now,it's looking like I'll be going with a "floor mount rear discharge" toilet mainly because of the help I've gotten here. I've been looking at various toilets to buy and am sort of intrigued by the ones that are known as "tankless flushometer" toilets. I'm intrigued because they look like the kind of toilet you see in a public restroom. didn't think they'd be used in residences but I've read that these are getting popular. (and the ones I've looked at are cheaper) they're also supposed to be more reliable. anyone have any experience with these? any comments?
tnx,
analogmusicman is offline   Reply With Quote
Old 05-04-2015, 04:38 PM   #19
As long as you use a 3/4" water to it it should be fine. You also need enough water pressure.
Old 05-04-2015, 07:43 PM   #20
Rewards Points: 560
yes,I read today that they need a healthy volume of water and this means a min. 3/4 supply...have to look into that. pressure should be no problem since I've got 90+ coming into the house.
tnx,
Old 05-05-2015, 06:26 PM   #21
Rewards Points: 560
I think I'm back to buying a regular "gravity flush toilet". although the pipes going to my proposed toilet location are 3/4", all the stuff I've been reading today says that I need 1" min. for a flushometer type toilet to work. 3/4" would be the max. size pipe in this house anyway since the water meter is 3/4". sort of makes you wonder how anybody gets a flushometer to work in their residence 'cause I think it's kind of rare for 1" pipes to be found in any bathroom,isn't it?
tnx,
Old 05-07-2015, 09:59 PM   #22
Rewards Points: 560
You'll need a 3 3/4 in center off the floor to mount a floor mount rear flush toilet. I would suggest getting the abs tee to see if it is a possibility. Remember you need at least 1.5 inch piece of pipe off the bottom of the tee for the adapter coupling connection.
You also need to maintain the clean out. Use a pro flex band coupling cast to plastic band.
You will also need a vent on the line .
Make sure when you frame you follow manufacture instructions .
I'm thinking of cutting off the "bell" on that cast pipe going into the floor,cutting the ABS and installing a "Fernco quick tee" (HD).The correct height of the tee off the floor will be gotten by how much of the cast pipe will end up protruding above the floor. sound like a plan?
by the way,are you talking about 3 3/4 in. because the pipe from the toilet needs some slope?
tnx,
Old 05-08-2015, 04:44 PM   #23
Yea I always allow a bit of pitch. Make sure you check your toilet specs for the tank rear flush. I forgot which one I checked but the toilet ran in the 200 dollar area.
Old 05-08-2015, 07:14 PM   #24
Plumber
Rewards Points: 302
Please don't use the rubber tee. They are not code compliant- they offer no rigidity to support the stack bearing down on it either.
You would be better off using a street sand tee attached to the cast iron with a Pro Flex coupling
The Following User Says Thank You to TheEplumber For This Useful Post:
Ghostmaker (05-08-2015)
Old 05-08-2015, 10:11 PM   #25
Rewards Points: 560
anybody have experience with "Niagara" toilets? it's between that and an "American standard".
tnx,
Old 05-08-2015, 11:12 PM   #26
NO fernco rubber crap tee allowed. We hang folks for that here.
Old 05-09-2015, 11:48 AM   #27
Rewards Points: 560
don't wanna get hung! so I guess I'll be using a regular old ABS "street tee"
tnx,
Old 05-09-2015, 10:39 PM   #28
Rewards Points: 560
hmm...isn't a 1/4"/foot pitch standard in DWV systems? I mean,this is something that's required by code isn't it? it's not just optional,right?
tnx,
Old 05-09-2015, 10:46 PM   #29
Plumber
Rewards Points: 302
tnx,
4" can be graded at 1/8"
dannyoung85 (05-09-2015)
Old 05-10-2015, 01:21 PM   #30
Rewards Points: 560
been doing some reading and it seems like nearly anything in the world of plumbing which is made of "rubber" is meant to be used underground only. am I close? is that why I was going to be hung for using a "Fernco quick tee" above ground?
tnx,
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 09:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Toilet wont drain chazlew Plumbing 11 02-27-2011 10:08 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Toilet Flange Install Junkster Plumbing 7 01-21-2008 09:44 PM
