Toilet Handle Points Up - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By joecaption
Old 10-05-2016, 01:52 AM   #1
Rewards Points: 16
Toilet handle points up
A tile guy removed my toilet in order to tile the bathroom floor and after he replaced it, the end of the handle now points up and the metal rod connected to the chain just rests on the bottom of the tank. Otherwise, the toilet works fine. The plastic nut holding the handle in place is tight and the handle isn't loose.
Anyone know how to fix this? Is there a part of the handle assembly designed to hold the handle in a horizontal position (e.g. by keeping the rod from tilting down too far), which may have broken off or got stripped? Should I just buy a new handle?
Mark777 is offline   Reply With Quote
Old 10-05-2016, 06:39 AM   #2
Rewards Points: 3,492
Re: Toilet handle points up
I agree with you, something probably broke or stripped. I would just buy a new one. Not that expensive.
jmon is offline   Reply With Quote
Old 10-05-2016, 07:20 AM   #3
Rewards Points: 18,990
Before I went and bought a new one I'd try removing the nut and repositioning it, then retighten.
It's a left hand thread
MTN REMODEL LLC likes this.
Old 10-05-2016, 02:53 PM   #4
Rewards Points: 16
Thanks guys. I just replaced it. With these cheap handle assemblies, there must be a little plastic stop molded into the fitting that strips very easily if someone puts any excess pressure on it.
The Following User Says Thank You to Mark777 For This Useful Post:
jmon (10-06-2016)
How easy is it to find replacement toilet of same profile/size daluu Plumbing 16 10-27-2013 05:56 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
How to handle toilet flange when leveling floor Homerepairguy Plumbing 11 12-08-2010 11:01 AM
Where to Move this Toilet? estburke Plumbing 8 10-10-2010 11:52 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
