Toilet Flange Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2016, 03:26 PM   #1
Rewards Points: 270
So ive removed the old flooring, down to concrete, removed the metal around the flange where the bolts hold on to, there is still the pvc portion still installed or glued in place, so i need to remove that carefully correct?
Once removed, is the best option to get the flange that goes inside the drain pipe and you screw tight to hold in place? or cement to existing drain pipe?
I have nothing in the area so if i need to remove some concrete around it to replace correctly i can do it now..
cubangt is offline   Reply With Quote
Old 07-11-2016, 04:16 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Toilet Flange Replacement
We need a picture or two----
Is the pipe white PVC?
Is the flange part of the 90 or a separate fitting?
3" or 4" ?
More info will get you the best answer.
Old 07-11-2016, 04:25 PM   #3
Rewards Points: 18,784
Why does it need to be replaced?
Old 07-12-2016, 07:59 AM   #4
Rewards Points: 270
The flange itself was metal surround with white pvc center, the pvc looks to be 3", will take pictures tonight when i get home.. and im replacing because the metal surround was damaged and we are laying new tile flooring and the previous owners didnt install the flange correctly, so the toilet always rocked side to side while using it.. so would rather do everything right.
Old 07-12-2016, 11:59 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Toilet rocking is not a flange issue, it is the toilet sitting on an unlevel floor.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Oso954 (07-12-2016)
Old 07-13-2016, 08:05 AM   #6
Rewards Points: 270
True it is not the flange, but because of the rocking that damaged the flange and has to be replaced.. i dont have a before pic, but posted a pic to my album of what it looks like now..
Old 07-13-2016, 08:07 AM   #7
Rewards Points: 270
Pic is now in my Bathroom Album
http://www.diychatroom.com/members/c...hroom-remodel/
Problem with toilet flange on top of tile floor wspev2244 General DIY Discussions 14 09-12-2015 07:55 AM
Toilet Flange Replacement costgeek Plumbing 6 04-15-2015 08:20 AM
tile and toilet flange benshouse Plumbing 3 12-29-2010 06:02 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 05:37 PM
