Toilet Flange Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2015, 09:50 AM   #1
Rewards Points: 374
Hey guys. I need to fix the subfloor under a toilet flange so I need to put in a new one. Looks like ABS with an outer connection (see pics). What's the best way to go about this?
costgeek is offline   Reply With Quote
Old 04-14-2015, 10:47 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 898
Is the pipe 3 or 4 inch.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 04-14-2015, 10:49 AM   #3
Rewards Points: 374
I think it's 3".
Old 04-14-2015, 07:59 PM   #4
Rewards Points: 1,952
Cut the 3 inch 1.5 inches above that 90 fitting. Then remove your wood floor and use a ABS 3 inch coupling and a new flange. Hopefully one with a stainless steel ring.
The Following User Says Thank You to Ghostmaker For This Useful Post:
joecaption (04-14-2015)
Old 04-15-2015, 06:58 AM   #5
Rewards Points: 374
Any issues with using a gasket flange?
Old 04-15-2015, 07:57 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 288
Yes, if your existing is 3". Pushing a new gasket flange inside the existing pipe will make the interior too small.
It would work on 4", but not 3".
If you don't want to open the ceiling then perhaps an inside cutter will reach. Then follow up with Ghost's suggested method.
http://www.homedepot.com/p/HDX-Inter...7516/204277491
Old 04-15-2015, 08:20 AM   #7
Rewards Points: 374
Yeah I was worried about that. The subfloor is up so I have plenty of room to make the cuts from above. Thanks guys.
Tags
abs , flange , toilet
Removing bolts from toilet flange a1481155 Plumbing 14 05-14-2013 07:10 AM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 12:18 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 08:07 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
