Toilet Flange Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2015, 11:15 PM   #16
Rewards Points: 77
I cut the hole and the upper patch.
I only need to do the larger patch that will hold the upper one from below.
Thank you again.
John
Slashp is offline   Reply With Quote
The Following User Says Thank You to Slashp For This Useful Post:
SeniorSitizen (05-20-2015)
Old 05-20-2015, 06:04 PM   #17
Rewards Points: 1,942
Is that patch not moving at all? I ask because your toilet will be fastened to a flange that in turn is fastened to that patch.
By the way if your installing a new toilet use the fernco waxless gasket.
http://www.amazon.com/Fernco-Inc-FTS.../dp/B000BQUJEA
The Following User Says Thank You to Ghostmaker For This Useful Post:
Yodaman (05-20-2015)
Old 05-20-2015, 06:07 PM   #18
Rewards Points: 77
Originally Posted by Ghostmaker View Post
Where is this house at? I see nothing venting it. 4 foot joist spacing?
There is a foundation wall around the house, with openings spaced regularly. House is in California.
Old 05-20-2015, 06:10 PM   #19
Rewards Points: 77
It moves since the picture I posted is just the dry fitting. I will cover the bottom of the plywood subfloor with a large patch of 1-in plywood screwed and gueld from below. And then I'll screw and glue the patch from the photo on top of it.
John
Old 05-20-2015, 06:43 PM   #20
Property Mgt/Maint
Rewards Points: 8,202
Now that looks like a better mouse trap! Never seen this before.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 05-20-2015, 09:49 PM   #21
What I liked about it is I could temporarily sit my toilet down with the Waxless so I did not have to run to the first floor during the night. Buy the correct size its long so your tile height is not a problem. It glues on the new toilet bottom soap it up so you can get it into the pipe easier with dish soap mixed with water. They been in for 7 years now and never leaked.
toilet flange question... edselsouth1 Plumbing 2 05-01-2013 11:13 PM
Question about toilet flange darius Plumbing 13 05-15-2012 11:16 PM
Changing out carpet for tile - toilet flange? M3 Pete Plumbing 4 02-16-2012 10:20 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Toilet flange question. speedster1 Plumbing 4 04-07-2010 10:30 AM
