Toilet Flange + New Vinyl Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2015, 04:17 PM   #1
Rewards Points: 288
toilet flange + new vinyl floor
Hi all,
Quick question - I have an ABS flange in good shape, bolted over top of the original floor, also in good shape (but ugly). I'm placing a t&g waterproof vinyl click floor down over the original, I don't want to cut / remove the pipe / flange to lay the new floor as this is ABS with offset, tied into original cast iron stack with no room to play. There isn't enough play in the plumbing to wiggle the new tile in underneath the flange, and even if there was, the click-lock-into-place tile makes this a bit difficult. So I'm cutting it to go around the flange and then sitting the toilet back on top of that new tile.
I'm losing about 4 mm or 1/16" of the original flange height with the new floor tile going in place. Can I assume that a standard wax seal (Oatey) will not be a problem with a bit less flange height now (and a bit more space to fill)? Will it still seal ok?. The old seal lasted @ 18 years without a leak - hoping I am just as fortunate this time around.
rtoni is offline   Reply With Quote
Old 09-28-2015, 04:31 PM   #2
Rewards Points: 6,334
All the standard wax seals ( if there is a standard ) I ever measured were 1" thick. Lay your toilet on its side, put a straight edge across the bottom and measure the recess depth, compare to the wax height on the flange where the wax ring will go. This will tell you how much crush there will be on a new wax seal.
It doesn't need to be smashed like this to seal.
Old 09-28-2015, 04:52 PM   #3
Rewards Points: 288
Thanks SeniorSitizen - good idea...
Old 09-28-2015, 04:57 PM   #4
Rewards Points: 582
it should work just fine....
Old 09-28-2015, 10:02 PM   #5
Rewards Points: 288
Thanks Ben - bathroom reno is pretty stressful so I may be worried more than I should be. Only done 2 other toilets, both new installs, same type of flange on top of finished floor, no issues with these - but I'm no pro so any deviation gets me thinking....
The Following User Says Thank You to rtoni For This Useful Post:
ben's plumbing (09-28-2015)
Old 09-28-2015, 10:13 PM   #6
griz's Avatar
Rewards Points: 572
You'll be fine.
Use the wax ring with the sleeve in it.
griz is offline   Reply With Quote
Old 09-29-2015, 12:52 PM   #7
Rewards Points: 288
thanks griz - that's the type of wax ring that I picked up - appreciate the sanity check....
Toilet flange and floor repair Brett924 Plumbing 3 04-28-2013 03:34 PM
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 10:45 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 07:58 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
