Toilet Flange Height Above Finished Floor - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By joed
Old 06-28-2017, 10:22 AM   #1
Rewards Points: 960
Toilet flange height above finished floor
I've read that toilet flange should be 1/4" above the finished floor. Does that height reference from :
- the bottom of the flange to the top of the finished floor
Or
- the top of the flange to the top of the finished floor
Also what size hole should I cut in the subfloor?
My plumbing is 4" cast iron.
Thanks!
jaketrades is offline   Reply With Quote
Old 06-28-2017, 11:18 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,924
Re: Toilet flange height above finished floor
It would be from the top of the flange to the top of the finished floor. Level with the floor would be what I would go for, if possible.
It's not all that critical. The wax ring will make up any difference. You definitely don't want it too small. There needs to be room for the wax ring.
SeniorSitizen and jaketrades like this.
Toilet flange not connected to floor rookie350z Plumbing 10 03-07-2016 02:44 PM
Toilet Flange Problem - New Tile Floor w/ Ditra qwkslvr Flooring 4 10-14-2009 10:04 PM
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 10:45 AM
toilet floor flange joseph44 Plumbing 4 07-15-2009 04:44 PM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 07:58 PM
