Toilet Flange Bolt Cutter - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-18-2015, 09:54 PM   #1
Rewards Points: 294
Toilet flange bolt cutter
Anyone recommend a toilet flange bolt cutter, easier the better.
Mikeron is offline   Reply With Quote
Old 12-18-2015, 10:04 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 162
I've been plumbing for quite some time. but I've never heard of this tool...
The Following User Says Thank You to TheEplumber For This Useful Post:
Mikeron (12-19-2015)
Old 12-18-2015, 10:05 PM   #3
Rewards Points: 294
Just something that will cut the bolt
Old 12-18-2015, 10:27 PM   #4
Rewards Points: 247
Hacksaw blade. Wrap a rag or something around one end and slip it between the toilet and the closet flange.
chemman is offline   Reply With Quote
The Following User Says Thank You to chemman For This Useful Post:
Old 12-18-2015, 10:36 PM   #5
Rewards Points: 1,852
Mini hack saws work great at this.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
gregzoll (12-18-2015), Mikeron (12-19-2015)
Old 12-18-2015, 11:15 PM   #6
Rewards Points: 6,652
Dremel with a cut off blade. Make sure you protect the toilet porcelain with a couple of layers of Duck Tape.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 12-18-2015, 11:16 PM   #7
Hacksaw, Dremel, etc.
Old 12-19-2015, 05:50 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
http://www.homedepot.com/p/TEKTON-8-...3386/205585550
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 12-19-2015, 08:30 AM   #9
Rewards Points: 294
Originally Posted by rjniles View Post
Oh yes that's what I'm thinking about, thank you.
Old 12-19-2015, 10:19 AM   #10
Rewards Points: 18,762
That would cut the bolt, but good luck ever getting the nut off again later.
Old 12-19-2015, 10:50 AM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Joe,
I have cut toilet bolts plenty of time with a bolt cutter, the nut will unscrew and re-cut the threads.
The Following User Says Thank You to rjniles For This Useful Post:
gregzoll (12-19-2015)
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
Tile around Toilet flange. Tile will be at Higher Level than Flange? crayola110 Tiling, ceramics, marble 0 09-19-2012 06:07 PM
3" ABS toilet flange 3 1/2" too high in basement floor fusion2k Plumbing 3 08-26-2012 12:41 PM
Advice for adding toilet flange. Blooze Plumbing 11 02-21-2012 02:50 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
