Toilet Fill Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2016, 12:45 PM   #1
Rewards Points: 58
Toilet fill valve
Just installed new Korky fill valve and after a couple weeks the toilet suddenly stops filling
Is it the fill valve or my supply?
Anybody have issues with Korky products?
saxsquad29 is offline   Reply With Quote
Old 01-06-2016, 12:54 PM   #2
ZTMAN's Avatar
Rewards Points: 604
http://www.korky.com/toilet-repair-troubleshooting
look at the first video
ZTMAN is offline   Reply With Quote
Old 01-06-2016, 03:47 PM   #3
Rewards Points: 58
Turns out that it was the supply line. It is Watts flood safe SS braided flex supply line and Impedes flow of water when it exceeds preset flow rate
Anybody use these supply lines?
Old 01-06-2016, 05:15 PM   #4
Rewards Points: 3,202
Yes. Pia. Get rid of it put in a regular ss supply line.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
rjniles (01-06-2016)
Old 01-07-2016, 11:14 AM   #5
Rewards Points: 1,336
The floodsafe lines were a good idea that never seemed to work properly. A lot of guys on here will suggest using a Stainless braided supply line. I won't. I use 3/8" brass tubing supply tines that you bend to shape and cut to size. What a lot of people don't realize about the braided lines is that they are nothing more than a rubber hose with a braided sleeve crimped onto a brass connection. I have seen them fail enough times to stop using them.
danpik is offline   Reply With Quote
Old 01-07-2016, 03:59 PM   #6
Rewards Points: 1,848
Tossed mine on the washer machine.
New fill valve toilet won't refill A330x Plumbing 2 01-04-2016 05:05 AM
Toilet fill valve spills water at top and emits bubbles when near filled daluu Plumbing 12 10-12-2013 09:12 PM
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 03:41 PM
Slow filing toilet, fill valve already replaced SupraTT Plumbing 4 12-24-2010 06:52 PM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 10:50 AM
