Toilet DWV Connections Between A Rock And A Hard Space - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-06-2018, 08:23 AM   #1
Rewards Points: 2
Toilet DWV connections between a rock and a hard space
Trying to configure a toilet drain installation that needs to fit in a 1'3" space between slab and bedrock. We don't want a raised floor, or to dig into granite. Do you think this will pass inspection? See attached.
Thanks!
jferguson is offline   Reply With Quote
Old 03-06-2018, 09:16 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,834
Re: Toilet DWV connections between a rock and a hard space
I'm not a plumber and gonna wait for our pro's.... (but I thought that vent had to come off vertical from the horizontal "trap arm" part.) But toilets can be xtra confusing to me, because the trap is in the toilet.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-06-2018, 09:19 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 248
Move the tee and sweep under the partition so the vent rises vertical
The Following User Says Thank You to TheEplumber For This Useful Post:
Ghostmaker (03-06-2018)
Old 03-06-2018, 09:28 AM   #4
retired framer
Rewards Points: 15,208
The vent could go up thru the wood wall just inside the foundation and save 2 elbows.
NickWa's Basement Renovation NickWa Project Showcase 50 07-01-2015 02:16 PM
constructing a crawl space. part ledge rock keepitmoving Building & Construction 1 06-16-2015 05:28 PM
Why does my newly installed toilet rock back and forth? TrailerParadise Plumbing 26 06-26-2013 12:06 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
