Toilet Draining Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2014, 08:24 PM   #1
Rewards Points: 66
Toilet draining question
We out in a new toilet a few months ago, and everything working fine. No leaking to report.
The past two weeks I've noticed after you flush you can hear the water drain very loudly through the bathtub drain. Prior to a couple weeks ago, you would t hear any water passing through as normal.
Does this sound like a deal or just one of those things?
ckandila2424 is offline   Reply With Quote
Old 12-28-2014, 08:46 PM   #2
Rewards Points: 19,008
Why was the toilet changed?
Is this bathtub used often?
A dry trap can cause that from lack of use.
A plugged up vent can also suck a trap dry when a toilet flushes.
ckandila2424 (12-28-2014)
Old 12-28-2014, 08:48 PM   #3
Rewards Points: 3,510
What you're hearing is the bathtub drain trap being siphoned so the system can obtain enough air to move the water flushing from the toilet. That will cause sewer gas to leak back into your house. When that happens, run the bathtub water after you flush the toilet for now until you figure out what is causing it.
May have a partial clog in the main line or clogged vent. Have to investigate a little further.
jmon is online now   Reply With Quote
The Following 2 Users Say Thank You to jmon For This Useful Post:
ckandila2424 (12-28-2014), TheEplumber (12-28-2014)
Old 12-28-2014, 08:58 PM   #4
Rewards Points: 66
The toilet was changed due to some updating to the bathroom after we bought the house, not for functionality reasons.
The bathtub has not been used since we bought the house over a year ago. The stand up shower also near the tub hasn't been used in a couple months because it was plugged up. We had a Plumber eradicate shower drain issue, but didn't start using the shower again, so it's been idle for 3 months
Old 12-28-2014, 09:08 PM   #5
Just had a post like this the other day. After you get the main line clear, run the water in the bathroom you are not using once in awhile to prevent that from happening again. Should be good.
Toilet flange question clambake6 Plumbing 18 03-07-2013 09:25 PM
another toilet hiss question nataled Plumbing 3 09-10-2012 07:21 AM
Question about toilet flange darius Plumbing 13 05-15-2012 11:16 PM
Fernco wax free toilet seal question? masterblaster4 Plumbing 2 07-21-2011 10:56 AM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 10:12 AM
