Toilet Drain, Slope, Vertical, Then Slope? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 09-10-2017, 04:08 PM   #1
Rewards Points: 46
Toilet drain, slope, vertical, then slope?
Wondering if this would cause an issue with drainage:
I plan to put a toilet about 8 or so feet from the waste stack. I can slope it for about 4 feet, then the drain is obstructed by a cross joist, due to how the floor was rebuilt some years ago. However, the floor below actually drops down a few feet, and is open from there to the stack. So I can put a elbow and a vertical, then I need to go to the stack again which is another 3 or 4 feet.
Will putting a vertical in between two slight slopes between toilet and stack be OK?
I attached a picture for clarification.
garwein is offline   Reply With Quote
Old 09-10-2017, 07:51 PM   #2
Rewards Points: 1,602
Re: Toilet drain, slope, vertical, then slope?
That should be fine. It's done all of the time. Are you using the stack as the vent?
mikegp is offline   Reply With Quote
Old 09-10-2017, 08:00 PM   #3
Rewards Points: 46
Yes, the stack goes straight up and is vented out the side of the house, above a lower level roof.
What if I went 45 degree instead of vertical for the short section that has to go under the joist?
Old 09-10-2017, 08:15 PM   #4
45s would probably be better. Less chance of clogging.
HvacSteve is offline   Reply With Quote
Old 09-11-2017, 07:44 AM   #5
Is this getting inspected? I think 8ft is greater than the allowable distance from the toilet to the vent.
MTN REMODEL LLC likes this.
Old 09-11-2017, 08:35 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,886
I think you want to wait for our plumbers to explain trap arm distances and horizontal run/slope.
MTN REMODEL LLC is offline   Reply With Quote
Old 09-11-2017, 08:57 AM   #7
retired framer
Rewards Points: 15,718
I think 10 ft for 4" pipe. not sure about the drop in the center.
Old 09-11-2017, 09:35 AM   #8
Rewards Points: 781
use 45 offsets.
ct18 is offline   Reply With Quote
Old 09-11-2017, 10:05 AM   #9
Rewards Points: 46
It's not getting inspected. I think the distance will probably be a total of 7ft, including the vertical or 45 degree drop, whichever I end up doing.
Old 09-11-2017, 12:24 PM   #10
THIS IS FROM A GC... I'm not a plumber.... but...
Normally, a trap arm is governed by a 1/4 slope before hitting it's vent.... and the length of that run is governed by the pipe size (which I think varies by UPC and IRC codes.
However, I am not sure of, and confused, in regard to a toilet... which to a limited sense (in time) has a self restoring trap.
Hence, I would wait for one of our professionals (whether you are under permit or not)
Just a personal opinion...
Good luck
Old 09-11-2017, 05:30 PM   #11
Rewards Points: 1,952
New York I can't help.
Old 09-11-2017, 05:33 PM   #12
Rewards Points: 114
That wouldn't fly around here. Looks like about 22' of pipe to the vent to me. 8' horizonally, 1' vertically plus 2 90s (+6' per 90). I'm sure there's a way to cut in a vent and run it back to the stack up high. AAV's are another option.
2x_Tom is offline   Reply With Quote
Old 09-11-2017, 09:35 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 290
UPC is 3"= 6' arm. That's from the flange to the tee. 4" is 10ft
The offset wouldn't fly
Old 09-12-2017, 06:07 PM   #14
Rewards Points: 46
I'm using 4" all the way.
I'm confused, so you guys are saying a 90 elbow adds 6 virtual feet to the overall length for venting purposes.
What about a diagonal with two 45s, would that be any different?
Old 09-12-2017, 06:14 PM   #15
Rewards Points: 114
A 45 would be better but but you still won't have a proper vent. Will it work? Maybe. Just get a real vent or even an aav up.
Running new kitchen drain because 1953 wasn't friendly with connection height scgt1 Plumbing 16 02-03-2017 11:57 AM
can I use/convert a toilet drain to a sink drain DanDaMan Plumbing 11 01-06-2017 11:07 PM
Anything wrong w/ toilet drain? jklingel Plumbing 8 11-06-2016 12:01 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
