Toilet Distance From Bell To Base - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2015, 08:57 PM   #1
Rewards Points: 109
Toilet distance from bell to base
In process of building bathroom in basement I'm working on. Just tiled the floor and installed the closet flange. Flange is on top of tile, and I'm not looking to debate if better on top or even with. It is on top. Closet flange is PVC drain and Stainless steel ring. Sits up about 3/8" inch higher than tile. I have not bought a toilet yet.
My question is under the toilet what is the distance from the face of the bell/drain/hole whatever you call it to the base of the toilet that will be resting on the floor tile. Being that the flange sits about 3/8" above the tile and the wax ring is probably about 1-1.5" thick I'm hoping that there is at least 5/8" of an inch gap on a standard toilet so that there is enough room to compress the wax ring and not bottom the toilet out on the closet flange. Anyone know? I check toilet drawings for in stock toilets at HD website but it only gives basic dimensions and not this one I'm looking for. Thanks
Olcrazy1 is offline   Reply With Quote
Old 01-11-2015, 09:21 PM   #2
Rewards Points: 1,938
I would suggest you just get the bottom and dry fit the toilet. If it doesn't sit on the floor try another brand.
Why did your flange end up not sitting on the tile itself?
Old 01-11-2015, 09:32 PM   #3
Rewards Points: 109
The flange does sit on the tile. Once I get the toilet I can flip it and run a level and just measure the distance, at 3/8" it will bottom out so it it needs to be 1/2" or larger. The closet flange is resting on top of the tile, see the picture below. I know some people install the flange first and tile around it. I decided to tile first and then drop the flange in securing it through the tile into the concrete floor under the tile. Here is a pic of what I'm working with.
Old 01-11-2015, 09:34 PM   #4
Rewards Points: 109
View from a bit further away
Old 01-11-2015, 09:43 PM   #5
Rewards Points: 582
don't know what your worried about...looks to me that any commode with a standard bowl wax with horn will work....good job..
The Following User Says Thank You to ben's plumbing For This Useful Post:
TheEplumber (01-11-2015)
Old 01-11-2015, 09:47 PM   #6
Rewards Points: 109
Thanks. Just wanted to be sure that the bell was not on the same plane as the base. I don't see enough of these to know and only way to find out is to buy one and bring it home which I will in due time. Need to finish up the bathroom first.
The Following User Says Thank You to Olcrazy1 For This Useful Post:
ben's plumbing (01-11-2015)
Old 01-11-2015, 09:54 PM   #7
Rewards Points: 582
the bell your talking about will insert if needed into the opening of flange ...
Old 01-11-2015, 10:17 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 18,428
I just recently did two toilets in my house.
The Flange does sit on top of the floor. I have the same one....except it's black vs white (not sure why the differences by location)
Make sure you have blocking under it for the screws to screw into. I used 2 1/2" SS screws.
I installed Toto toilets, but any of the new ones will fit fine.
Note: that knock out plate that is for pressure testing....when you are ready to install the toilet you will remove that. There is also a ring in there that may not come out with the knock out. If you don't remove that inner ring, the toilet will not sit flush.
Don't be afraid to test fit before you use the actual wax ring.
One little trick I figured out. I marked the center point on the floor and on the front of the bowl. It makes it a lot easier to set the toilet.
I'm also one of those that puts a bead of silicone around the bottom of the bowl....let it set for about 45 min and then put into place. If you have boys, it prevents their 'misses' from going under the bowl and fermenting.
Leave about a 1" gap in the back of the bowl. That way if you have a leak, you will see water back there and know where it's coming from.
Old 01-11-2015, 10:21 PM   #9
Plumber
TheEplumber's Avatar
You have installed the lowest profile flange I know of.
I see no reason for concern
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (01-12-2015)
Old 01-11-2015, 10:51 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
outlet is parallel to the outer rim line of most toilets if your flange is set correctly the bell will sit inside and below the flange rim, you should be able to set the toilet with out a wax seal flush it and if its lined up correctly you'll have no leaks, the wax is actually to seal off gases and not water.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-12-2015, 08:47 PM   #11
That is a properly installed flange a very nice job.. Should have no problem with any toilet.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Toilet base is surrounded by grout New_2_DIY Plumbing 15 08-24-2011 12:27 PM
Water pooling around the base of the toilet mrsp48 Plumbing 5 06-05-2010 11:16 AM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
