Toilet (Delta) Water Wont Go Down - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By hkstroud
Old 12-17-2016, 11:51 AM   #1
Rewards Points: 90
Toilet (Delta) water wont go down
Delta toilet fairly new don't exactly know how new since i bought the house a year ago, when i flush the toilet the bowl fills and swills I tried an auger and it went thru no debris on it either.
tried using the detergent technique over night didnt work also the water i dumped in wouldnt go down either but eventually drained after 20 minutes ,tried plunging too.
what other techniques should i try if any before replacing the toilet?
JoeF77 is offline   Reply With Quote
Old 12-17-2016, 12:00 PM   #2
hkstroud's Avatar
Rewards Points: 6,694
Re: Toilet (Delta) water wont go down
You pull the toilet and snake the line. You have a blockage (a partial blockage, but a pretty significant one) in the line. You say that you snaked the toilet. I assume that means you snaked with toilet auger. A toilet auger only extends down to the drain pipe. It is not long enough to get into the pipe. Your blockage is in the line.
Bondo and de-nagorg like this.
hkstroud is offline   Reply With Quote
The Following 2 Users Say Thank You to hkstroud For This Useful Post:
Ghostmaker (12-17-2016), JoeF77 (12-17-2016)
Old 12-17-2016, 12:16 PM   #3
Rewards Points: 1,054
Wax rings are cheap. If you can't get the toilet to flush, pull it and do the bucket test. Fill up a few 5 gal buckets and quickly dump them down the toilet flange. If it doesn't drain as quickly as you can pour the buckets, then something is wrong. 3" and 4" pipes can move a lot of water.
clarenceboddick is offline   Reply With Quote
The Following User Says Thank You to clarenceboddick For This Useful Post:
JoeF77 (12-17-2016)
Old 12-19-2016, 02:59 PM   #4
Rewards Points: 90
well snaked the main 80 feet found a few roots didnt open the drain, it was clogged from in the house pulled the toilet snaked into the main line busted the clog open turns out it was alot of grease in the pipes
Old 12-19-2016, 05:45 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,324
Ayuh,..... Which is Why grease goes in the trash, 'n not down the drain,....
Old 12-19-2016, 06:01 PM   #6
hkstroud's Avatar
You never put anything down the toilet that you haven't eaten first.
Harold,
The Left Handed Widget Maker
Old 12-19-2016, 06:26 PM   #7
Rewards Points: 90
just bought the house in january im guessing the grease was already there and hair and soap clung to it and made it worse.... anyone use bio clean for maintaining clean pipes?
Old 12-19-2016, 06:38 PM   #8
Rewards Points: 3,512
Yes, very good product imo.
Use it in the kitchen drain.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
JoeF77 (12-20-2016)
Old 12-19-2016, 06:55 PM   #9
Rewards Points: 90
should i start it in the basement sink first then move onto the upstairs kitchen ??
Old 12-19-2016, 07:10 PM   #10
Doesn't really matter where you start. You can do both at the same time. It takes time to work. It won't be an overnight process.
Just make sure the drain lines you are treating are not clogged and have been snaked and cleared if they are, then use it as a preventative measure for keeping the pipes clear.
Old 12-20-2016, 08:23 AM   #11
Rewards Points: 90
yea i just snaked both inside out to the street 80 feet probably be wise to use bio clean and root x from now on
Old 12-20-2016, 10:14 AM   #12
hkstroud's Avatar
If you have tree roots start making plan to dig up the line and replace. Kill the tree.
Harold,
DIY Tips and Tricks! DangerMouse General DIY Discussions 171 09-04-2015 09:50 AM
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
