Toilet Bowl Won't Empty When Water Supply Is Off. - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree8Likes
  • 2 Post By Oso954
  • 1 Post By MTN REMODEL LLC
  • 2 Post By SeniorSitizen
  • 2 Post By MTN REMODEL LLC
  • 1 Post By 3onthetree
Old 11-08-2019, 01:02 PM   #1
Rewards Points: 165
Toilet bowl won't empty when water supply is off.
I'm replacing a toilet in Florida and I'm seeing a phenomenon I haven't seen before. When I shut off the water supply, the bowl won't empty. The tank basically empty but the bowl stays full no matter what. Turn the water on and the toilet works like normal. Ordinary looking toilet. No idea what is going on, but don't want to lift up this toilet with a bowl full of water. Help please.
wengang1 is offline   Reply With Quote
Old 11-08-2019, 01:07 PM   #2
Oso954's Avatar
Rewards Points: 58
Re: Toilet bowl won't empty when water supply is off.
After flushing the toilet to empty the tank, use a plunger to force most of the remaining bowl water down the trap.
If you want to pull more water out, you can use a turkey baster or a wet/dry vacuum.
Oso954 is offline   Reply With Quote
Old 11-08-2019, 01:47 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 126
or a thirsty dog.....
(That's exactly how that toilet is supposed to work)
SeniorSitizen likes this.
MTN REMODEL LLC is online now   Reply With Quote
Old 11-08-2019, 02:49 PM   #4
Rewards Points: 2,202
I siphon with clear poly water hose about 3/8" dia. but you gotta know when to quit sucken, spit-spit.
MTN REMODEL LLC and lenaitch like this.
Old 11-08-2019, 03:27 PM   #5
Rewards Points: 7,243
You can bucket flush the bowl to remove the maximum amount of water. Then it's time to bail using any method above or small cup.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 11-08-2019, 04:06 PM   #6
Big Dog
Drachenfire's Avatar
Rewards Points: 4,082
Ditto on using the shop vac. I do this every time I have to change a toilet which results in almost no water mess when the toilet is pulled out.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Old 11-08-2019, 11:11 PM   #7
Usually Confused
lenaitch's Avatar
The bowl is doing what it is supposed to do - it is acting just like the trap under a sink. All sorts of methods described above. I've just used a plunger then mop out what's left.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old 11-09-2019, 10:32 AM   #8
Rewards Points: 18,040
If you do use a shop vac, remove the filter first.
Old 11-09-2019, 10:47 AM   #9
That's why I siphon, nothing to do other than spit-spit.
Old 11-09-2019, 11:09 AM   #10
Rewards Points: 126
Or hope you don't have to spit-spit.
Ya know....the other night I got pretty drunk, went to sleep, and dreamed I drank the largest Margarita in the world.
(Got a little worried the next morning when I found salt all around the toilet rim)
huesmann and SeniorSitizen like this.
Old 11-11-2019, 08:51 AM   #11
Rewards Points: 392
I would not self-siphon out of a toilet bowl.
I have a siphon hose from my aquarium days that has a little squeezy bulb on it that you can squeeze to pull water into the hose and get the siphon action going.
huesmann is online now   Reply With Quote
Old 11-11-2019, 09:07 AM   #12
After being on forums for a few years I've determined that siphoning is possibly rated in the top 10 of the human knowing very little about. That's kind of scary. Spit-Spit
Old 11-11-2019, 11:46 AM   #13
Hammered Thumb
Rewards Points: 248
I use a nice big rubbermaid to put it in and carry it out. First I just move it to the tub right next to it to get most of it out. I can lift it pretty level without spillage and then hover, but realize as I age I will have to find other ways. I'd siphon a tank reluctantly, but in case I'm not quick enough certainly won't be siphoning the bowl just thinking about years of crap (literally) stuck to the sides of the trap.
huesmann likes this.
3onthetree is offline   Reply With Quote
Old Today, 12:20 PM   #14
Rewards Points: 708
The toilet is designed to block out sewer/septic gases from entering the room. I get as much out as I can with a measuring cup and then lift the toilet and dump what is remaining into a wash basin on the floor.
Calson is online now   Reply With Quote
