Toilet Bowl Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-03-2017, 10:33 AM   #1
Rewards Points: 312
Toilet bowl question
Seems like my bowl should / could have more water to make more of a 'complete' flush... is there a way to send more water from the tank to the bowl after each flush?
KPDMinc is offline   Reply With Quote
Old 04-03-2017, 10:49 AM   #2
JUSTA MEMBER
Rewards Points: 3,800
Re: Toilet bowl question
New model or older model?
Most new ones are water savers, and are designed for less water.
It will only accept as much as necessary to not flow over the trap in the body of the unit, any more will just trickle away.
ED
de-nagorg is online now   Reply With Quote
Old 04-03-2017, 10:55 AM   #3
Rewards Points: 312
ED
Its a pretty new Kohler
Old 04-03-2017, 11:09 AM   #4
Rewards Points: 680
Some of the low flow toilets require you hold the flush handle down to dispose of #2...
LawnGuyLandSparky is offline   Reply With Quote
Toilet bowl leaks and rocks--Is flange too high? Daneel Plumbing 5 01-26-2015 10:01 PM
Water Draining From Toilet Bowl FClef Plumbing 4 02-04-2014 07:56 PM
Toilet Bowl Mystery roztom Plumbing 5 01-31-2014 11:05 AM
Faulty toilet bowl? New toilet, gasket leak Fritzav Plumbing 3 10-23-2013 03:25 PM
Saniflo toilet bowl water level vtboy51 Plumbing 2 06-29-2010 08:33 AM
