Toilet Bowl Has Low Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2015, 09:01 AM   #1
Rewards Points: 1,104
Toilet bowl has low water
2 yo Kohler. No previous problem. Septic.
Why does tank fill correctly with water but the bowl water is noticably low?
Someone used it who has always said they use too much TP.
Startingover is online now   Reply With Quote
Old 11-02-2015, 09:22 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Check out he refill tube is pumping water into the overflow during refill.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following 4 Users Say Thank You to rjniles For This Useful Post:
jmon (11-02-2015), oh'mike (11-02-2015), raylo32 (11-02-2015), Startingover (11-02-2015)
Old 11-02-2015, 10:18 AM   #3
Rewards Points: 3,216
Post some pictures of inside the tank. Thanks.
As rj mentioned, see if water is coming out of the fill valve hose going into the re-fill tube during a refill. If it's a weak stream, that could indicate fill valve is leaking and needs replacing. Just a suggestion.
Others will be along with more suggestions/ideas. Hope you get it working right soon.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Old 11-02-2015, 11:13 AM   #4
I feel silly. I knew the toilet sounded 'different'. I've been flushing it all morning hoping it would self-repair. When I took photo I noticed the white water hose popped out. (Why). I'll stick it back in to the level of the stain.
Someone is storing an over-the-toilet eterage here so it makes it harder to see the tank.
The Following User Says Thank You to Startingover For This Useful Post:
jmon (11-02-2015)
Old 11-02-2015, 12:12 PM   #5
It happens, probably wasn't stuck in there enough and loosened up and popped out or you may need to replace the rubber hose if it's getting too loose. Should fit in there snugly. Just a suggestion.
Nothing to feel silly about. Chalk it up as an easy fix. Glad everything is working right again.
Old 11-02-2015, 03:01 PM   #6
Rewards Points: 5,520
OMG, I've got to remember that phrase.
QUOTE: Startingover - "hoping it would self-repair"
That's a classic.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 11-02-2015, 08:50 PM   #7
Rewards Points: 1,042
Attachment 212705
The white hose should have a holder clamped to the side of the overflow tube,probably rusted out.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Startingover (11-03-2015)
Old 11-03-2015, 09:34 PM   #8
Canarywood, Theres no clamp. Should I buy them and are they easily found in Home Depot? I have another Kohler, same age and it doesn't have a clamp either.
Old 11-03-2015, 11:22 PM   #9
Rewards Points: 188
That's a classic.
Sounds like someone who works with computers or electronics all day. Give them a quick power cycle or reboot and things are back working. Shouldn't a toilet flush accomplish the same, where jiggling the handle properly is like giving your computer the three finger salute.
RustNeverSleeps is offline   Reply With Quote
The Following User Says Thank You to RustNeverSleeps For This Useful Post:
Startingover (11-04-2015)
Old 11-04-2015, 07:24 AM   #10
Y'all will get a real laugh out of this.
I'm teaching my daughter how to do small repairs around the house. LOL. Actually, I told her to join this site.
Old 11-04-2015, 07:54 AM   #11
Rewards Points: 5,348
If the tank is losing water, there are two reasons: 1. The flapper isn't sealing properly. 2. The water isn't getting into the tank to begin with. Easily diagnosed when you flush the toilet.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 11-04-2015, 08:14 AM   #12
Has she memorized the " self repair phrase "? ROTF
Old 11-04-2015, 01:58 PM   #13
I've never seen them alone, they are usually in a repair kit, but that's not to say they don't sell them alone, ask the next time your at the box store, in the plumbing dept.
Old 11-04-2015, 07:46 PM   #14
Those newer kohler toilets have a cannister type flush valve and have no clamps for the hose. Not the best design imo but it is what it is.
As stated above, fill hose just fits in there snugly, that's it. If not, replace fill hose. Just a suggestion.
Guess That Leak! w/photos Oh-Fudge Plumbing 20 11-18-2014 11:57 AM
Water in our toilet bowl sucks out? Bluwolf Plumbing 6 04-23-2011 09:23 PM
No Water entering toilet bowl mjarema414 Plumbing 5 05-03-2009 01:39 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
toilet water nikotromus11 Plumbing 7 03-18-2008 07:47 PM
