Toilet Bolt Loose - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2017, 12:28 PM   #1
Rewards Points: 52
toilet bolt loose
Hi,
toilet is 10 years old. No issue - no rocking, no moving. Today, i noticed bolt on one side was very loose. So i tightened it up.
Would a loose bolt suggest wax ring might require replacement ?
mf915 is offline   Reply With Quote
Old 04-30-2017, 12:52 PM   #2
Property Mgt/Maint
Rewards Points: 8,202
Re: toilet bolt loose
If it's not leaking, no need to assume it is going to. Snug the bolt(s) and call it good.
A visual inspection from the bottom side would be a plus if possible.
Yodaman is offline   Reply With Quote
Raising Toilet level / loose flange bolt Zach_C Plumbing 1 01-24-2015 02:18 PM
Toilet flange loose lead insert questions mikemcd Plumbing 10 09-06-2014 07:19 PM
leaks on rear base of toilet & water supply valve Nospammer Plumbing 1 08-16-2012 03:21 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
