Toilet Adjustment - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-07-2015, 06:43 AM   #1
Rewards Points: 384
Toilet adjustment
I have an American standard toilet and there is not enough water left in the bowl after flushing to keep the sewer gas from coming up. I would like to know how to adjust this, the manual for the toilet does not give this information. Thanks
shirbon is offline   Reply With Quote
Old 11-07-2015, 06:52 AM   #2
Property Mgt/Maint
Rewards Points: 8,184
is there a rubber hose connected to the top of the fill valve? If so is the other end dropped into the overflow tube?
[political signature removed]
Yodaman is offline   Reply With Quote
Old 11-07-2015, 07:57 AM   #3
Rewards Points: 384
The rubber hose is outside the fill tube
Old 11-07-2015, 08:33 AM   #4
Rewards Points: 3,208
As mentioned in post 2, make sure hose is attached to fill tube.
Sometimes the clamp rusts out or hose becomes dislodged/worn and needs to be replaced.
jmon is online now   Reply With Quote
Old 11-07-2015, 09:22 AM   #5
Rewards Points: 384
Yeah after I read the first reply the light bulb came on and I moved hose inside tube and seems to work better now. Thanks all
The Following 3 Users Say Thank You to shirbon For This Useful Post:
jmon (11-07-2015), oh'mike (11-07-2015), Yodaman (11-07-2015)
Toilet Float Adjustment Screw is squirting! enkoopa Plumbing 3 02-06-2012 11:25 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
