Toilet 1/16 Rocking Front And Back - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2016, 03:24 PM   #1
Rewards Points: 2
Toilet 1/16 rocking front and back
I just installed a new American Standard toilet (it has a long base to it), due to my floor tiles, it does not sit flush with the floor. There is a very small gap of 1/16 between the floor and the front of the toilet base, causing a slight rock. Now it doesn't rock when i sit on it, it only rocks when i physically lift the toilet from the front (I can lift it ever so slightly). Would acrylic caulk fix this?
My previous toilet didn't need shimming, but the base from the front to back was not as long as my new toilet, so im guessing with the caulk on my previous toilet was used to stabilize it enough not to move.
rpri032 is offline   Reply With Quote
Old 08-30-2016, 04:26 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Toilet 1/16 rocking front and back
Bad news for you.
Yes--you needed to shim that and then secure the shims with some caulk.
Now that the toilet had been rocked several times, the wax seal may be leaking---
I suggest re-setting the toilet with a new wax ring----your call---
Toilet not flush with floor in front right!! L.Young Plumbing 1 10-09-2015 06:42 AM
Window popped out in traffic! Bigplanz Automotive Repairs 12 06-27-2015 06:35 PM
Handy tips for a happy house-- oh'mike General DIY Discussions 67 05-11-2014 07:39 PM
Shimming toilet?? dpach Plumbing 22 05-09-2012 03:17 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
