Toile Flange Too Close Too Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-01-2016, 12:49 PM   #1
Rewards Points: 1,184
Toile Flange too close too wall?
We had this toilet installed about a year ago and believe it or not it was never really tightened all they down. We don't use it much. He had to trench th floor and tie into the main line. I had to replace th wax ring and the back of the "neck" hits the wall slightly and when I install the tank it hits th wall too. i don't know what this guy did to get it on there but like I said it was always a bit loose....maybe that's why. Do they sell toilets with shallower "necks"? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 10-01-2016, 01:01 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,834
Re: Toile Flange too close too wall?
Not sure of the actual dimensions you are playing with there.
But, you can find (not many but available) toilets made for a 10" (vs 12") setback. That might help.
Also, you can use an adjustable flange and get additional offset (either sideways or back/forth. That might help.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Mstrlucky74 (10-01-2016)
Old 10-01-2016, 02:22 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 248
Yes, toilets are available for a closer set, but be careful how they go about achieving it. Some toilets do it by moving the flange holes 2". Others simply make the tank depth 2" narrower. This would mean the bowl will still hit.
Sent from my HTC6525LVW using Tapatalk
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 10-01-2016, 02:36 PM   #4
Think I'm going to try and look into adjustable flange before buying new bowl.
Old 10-01-2016, 05:51 PM   #5
Rewards Points: 1,932
Could you measure off the dry wall to your tbolts on that toilet please.
Old 10-02-2016, 12:23 PM   #6
Originally Posted by ghostmaker View Post
could you measure off the dry wall to your tbolts on that toilet please.
11.5"
Need Some Advice About A House With An Issue neutropia General DIY Discussions 7 01-29-2017 06:46 AM
Building a retention wall close to easement drain smartsid Concrete, Stone & Masonry 11 01-11-2016 12:27 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Water in crawlspace, dug out too close to foundation, How to fix? Build a wall? twilightcall Building & Construction 6 05-18-2009 09:16 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
