Tips On Holding No Hub Cast Iron In Place While Making Drain Run. - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By TheEplumber
Old 05-03-2017, 02:51 PM   #1
Rewards Points: 960
Tips on Holding no hub cast iron in place while making drain run.
I'm making some tricky plumbing runs in tight spaces. It seems like half the battle is holding the pieces in place while determining the next piece to the puzzle. I'm trying to solve from the ptrap to the long drain run.
I've tried holding the pieces in place with pipe straps but it keeps wobbling and finally falling off.
I'm working with an open subfloor.
jaketrades is offline   Reply With Quote
Old 05-03-2017, 08:02 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 254
Re: Tips on Holding no hub cast iron in place while making drain run.
Sometimes it helps to put the coupling on and snug it down a bit- then measure
Other times you need a third hand to hold something- do you have a helper?
There's an old saying- "measure twice, cut once." Sometimes you just got to eyeball it and cut twice
jaketrades likes this.
The Following User Says Thank You to TheEplumber For This Useful Post:
jaketrades (05-03-2017)
Old 05-03-2017, 08:11 PM   #3
Rewards Points: 960
I've got the couplings on.
I don't have an extra pair of hands. I need a joist brace type device for the pipes. Where I can jam it against the inside of the joists.
If I wasn't on my last drain setup, I'd buy two joist braces and drill some pipe clamp type devices to them. Unfortunately I'm at the end of my struggle.
Shower Drain for cast iron shower pan Rich Plumbing 2 03-08-2013 01:29 PM
How should i repair this cast iron drain leak? markcal02 Plumbing 14 10-20-2011 05:03 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
cast iron roof drain that is rotted steves smith Plumbing 2 09-22-2010 11:48 PM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
