Tile Backer Board And Torch - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2017, 01:50 PM   #1
Rewards Points: 278
tile backer board and torch
I need to repair the water lines in the wall of my tub/shower. Two lines are very close to the tile concrete boards. How much heat can this concrete board take and any suggestions on protecting the stud and other areas? I have done copper sweating before but never in an enclosed area as this. My 1st purchase will be a fire extinguisher.
captfl2x is offline   Reply With Quote
Old 08-13-2017, 02:44 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,532
Re: tile backer board and torch
It won't be so much the CBU, as it is fireproof for the most part (it's concrete), BUT the tile attached to it may crack due to the heat. I would purchase the fire extinguisher, PLUS a heat pad. http://www.homedepot.com/p/9-in-x-12...4002/100345508
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 08-13-2017, 06:26 PM   #3
Rewards Points: 278
Thanks for the fire pad link.
Old 08-13-2017, 10:59 PM   #4
retired framer
Rewards Points: 15,280
I would still protect the concrete from heat as it can explode
Old 08-14-2017, 06:45 AM   #5
hkstroud's Avatar
Rewards Points: 6,694
A piece of aluminum foil folded about four times makes a nice heat shield. Tacked to stud with thumb tack. Assuming that you are soldering 1/2 copper it shouldn't take but about 30 seconds of heating each joint.
What kind of a torch are you using?
You didn't ask, but you don't engulf the pipe or fitting (you always heat the fitting) in the flame. Apply the tip of the flame to the joint. The tip of the blue flame with in the yellow flame is the hottest point.
Have a bucket of water and wet cloths handy.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 08-14-2017, 10:07 AM   #6
Rewards Points: 278
in all of my previous sweats, I've always used a propane torch. Total sweats? maybe 20-30. Never any leaks. . My concerns about this project are the very small access area and the close proximity of flammables. After the fire extinguisher purchase, the next will be an instant on/off self igniting torch head. The last thing I need is a full flame going in circles in a confined area while I'm trying to cut it off. Thanks for all the shielding advice.
Torch on roof alternatives... bcbud3 Roofing/Siding 7 10-27-2013 10:39 AM
a torch down problem crept up Dizz Roofing/Siding 7 06-16-2012 10:52 AM
torch down small roof section ernst Roofing/Siding 8 07-10-2009 04:04 PM
