Are Tighter Fittings OK For Sewage Ejector Pump Waste Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2017, 10:30 AM   #1
Rewards Points: 2
Are tighter fittings OK for sewage ejector pump waste line?
I'm installing an ejector pump that will pump waste up about 6 feet to an existing 3" waste line on the ceiling of my basement. My question is about splicing the 2" waste line from the ejector into the 3" waste line, this splice is below the kitchen, toilet and bathroom sink waste inlets. I've read (and common sense) tells me that the 2" line should rise, turn, then come down at the 3" from above. I do not have a lot of room overhead or around the 3" waste line, can I use tighter fittings to make this turn, given that the waste is pumped mechanically, or best to stick with longer sweeped turns?
Thanks much!
coupergear is offline   Reply With Quote
Old 09-20-2017, 04:55 PM   #2
Rewards Points: 1,952
Re: Are tighter fittings OK for sewage ejector pump waste line?
Under IPC the ejector pump would need to tie into a 4 inch pipe using a wye fitting looking up.
Pumped waste are especially hard on vents so larger pipe is required.
Ptrap below waste line GT Adventures Plumbing 6 11-22-2014 02:20 PM
waste line in basement slab 7474 Plumbing 6 12-11-2008 06:38 AM
Toilet waste line slope? jadrma Plumbing 7 11-10-2008 05:04 PM
Is this a reoccurring clog in the toilet waste line? darsunt Plumbing 2 06-02-2008 11:11 AM
ice maker line in wall and fittings cshousley Plumbing 5 10-01-2007 04:01 PM
