Three Check Valves On Sump Pump? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By TarheelTerp
Old 02-25-2018, 07:20 AM   #1
Rewards Points: 123
Three check valves on sump pump?
Can anyone think of a reason to have three check valves on a sump pump? I installed a new pump yesterday and am redoing the old fittings. Its just a single pump, no backup. The old pump had a check right above the pit, another check at the top of the vertical pipe, and a third check right after the elbow on the horizontal pipe that exits the house. The valve at the top of the vertical pipe cracked so I removed it. I cant see the need for the check on the horizontal exit pipe. Before I remove that one too, does anyone know why there would be so many?
scottyv81 is offline   Reply With Quote
Old 02-25-2018, 09:40 AM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,702
Re: Three check valves on sump pump?
No good reason.
Bad reasons abound but probably just that each installer added HIS
check valve and avoided touching what he wasn't being paid to touch.
Mike Milam likes this.
TarheelTerp is online now   Reply With Quote
Old 02-25-2018, 09:44 AM   #3
Rewards Points: 6,580
If one has a perfect seal there's no need for more.
Check valves rate right up there for first prize of being the most un-reliable valve made. Depending somewhat on the pipe being used, what could have happened when the DIY person or a plumber thought No. 1 was failing he just added a second rather than replacing the failed valve because if that being simpler and No. 2 valve remained when No. 3 was installed.
SeniorSitizen is offline   Reply With Quote
Old 02-25-2018, 12:13 PM   #4
Rewards Points: 123
Thanks, you have both confirmed my suspicions! I prefer fewer leak points so Iím gonna stick with the single check at the pump.
Sump pump is pushing water up into the bath tub. Eh? roasted Plumbing 29 03-12-2017 07:59 PM
Sump Pump Stopped + Questions anyacolo Plumbing 12 01-23-2017 04:52 PM
Heating System Check Valves ajberezo Plumbing 2 04-11-2013 12:13 PM
Check Valve Choices for Sump Pumps jpepe3691 Plumbing 0 02-13-2012 01:37 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 04:35 PM
