Thinking About Adding Second Water Trunk Line..?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2016, 08:22 AM   #1
Rewards Points: 8
Thinking about adding second water trunk line..??
My house has 3/4 inch hot and cold pex trunk with 1/2 pex t'd off of it to feed the sinks, showers, etc. It is a two story with two full baths on the second floor and the main has master bath with a separate shower and tub. I have 3 daughters and my wife in the house and many of the showers and tubs seem to be turned on at the same time. Which has effected water pressure. Yes, I can tell them not to take a bath at the same time...but some things are easier than others... I am in the process of finishing the basement and was thinking about running another 3/4 line to feed the downstairs finished bath and also feeding the master walk in shower (right above the lower bath and easy to re-pipe). The hot water heater has a 3/4inch going out and so does the water softener.
Will adding another 3/4 trunk line off of the 3/4 hot and cold water outlets improve any water pressure loss from the upper baths if they are on a separate trunk?
mamalone00 is offline   Reply With Quote
Tags
pex installation , trunk lines , water pressure loss
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
