Thermostatic Shower Valve Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2016, 10:28 PM   #1
Rewards Points: 12
Hello folks,
Trying to help a friend, and trying to avoid calling a plumber if possible. She has a thermostatic shower valve which was installed in 2004. Since then, it had worked flawlessly, until today. The temperature range used to be from cold to hot (maybe 125-130F). As of today, it goes from cold to barely warm (maybe 80-85F). Does anyone know if this is a simple fix, or are we looking at a new valve?
I tried to take it apart to have a look, but when I loosen the screw under the small cap in the front, it just makes the temperature control loose, but I can't get it off. I'm afraid to pull to hard and break it. Any advice on that one?
Here is a picture of the trim if it helps any:
Thanks,
Joe
supercubber is offline   Reply With Quote
Installing bath and shower mixer valve... thomasl12 Plumbing 10 04-02-2015 07:20 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Shower Valve Rough In Tips? ddawg16 Plumbing 2 09-30-2012 08:24 PM
Price-phister Shower hot side two valve O-Ring replacement? Bozohelp Plumbing 11 06-14-2011 04:44 PM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 04:37 PM
