Thermocouple Nut Will Not Screw In - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2016, 07:52 AM   #1
Rewards Points: 294
Thermocouple nut will not screw in
The nut attached to copper gas line will not screw back in, does it have a reverse thread, tighten the opposite way to normal.
Mikeron is offline   Reply With Quote
Old 02-23-2016, 09:07 AM   #2
Rewards Points: 6,652
Turn opposite way until it catches the thread, then slowly thrn to make sure you are not cross threading.
Old 02-23-2016, 11:31 AM   #3
Rewards Points: 459
Regular right hand thread, but as gregzoll said, you gotta be really careful to not cross thread it. You also have to make sure you're going in perfectly straight. It's easy to get just a little bit crooked and it won't work.
Nick DIY is offline   Reply With Quote
Old 02-23-2016, 05:36 PM   #4
Rewards Points: 582
picture of what you have will help us help you...is this on a whirlpool water heater...
2 screw outlet vs 4 screw outlet RayFred Electrical 14 01-30-2016 06:29 PM
How to remove screw stuck in the wood? higv2000 General DIY Discussions 13 06-30-2012 01:40 PM
Input for a Screw Guide Card marriomi Carpentry 5 06-28-2012 11:05 AM
Thermocouple and Gas Valve dimjim HVAC 10 03-22-2011 10:05 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
