Thermal Expansion Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2016, 08:22 PM   #16
Rewards Points: 582
new code for water meter installations ..dual check valves required and pressure regulators if incomming pressure is to high ...1991... so if any home has a pressure regulator, or check valve in the system ..that makes it a closed system..which requires a thermal expanison tank in the system to absorb thermal expanison of heated water from water heater......
Old 01-19-2016, 08:31 PM   #17
WhatRnsdownhill's Avatar
Rewards Points: 2,220
when you have an rpz on the main, yes expansion tank is needed, but not just for a hot water heater...
WhatRnsdownhill is offline   Reply With Quote
Old 01-19-2016, 08:33 PM   #18
Originally Posted by TheEplumber View Post
Since he has a PRV he has a closed system. Previous history aside, I'm betting it is now a code requirement for his jurisdiction
I agree if code changes you can put one in, but op didnt state in first post and systems been fine for how many years...
Old 01-19-2016, 09:05 PM   #19
Rewards Points: 1,862
Basic physics when you heat something it expands. On a closed system if it has no where to go it will trigger the T&P on the hot water tank to start tripping off. A Pressure reducing valve normally has a bypass back to the water provider. But the problem is it eventually clogs then T&P trips and stuff gets wet.
Old 01-19-2016, 09:38 PM   #20
Smile
I missed that the op had a prv in the main...
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
TheEplumber (01-19-2016)
Tags
expansion , heater , tank , thermal , water
Fil-Trol expansion tank maddog1 Plumbing 2 12-19-2012 04:58 PM
Old expansion tank leaking Ultrarunner2017 HVAC 7 11-16-2011 06:40 AM
Recommended thermal expansion tank brands downunder Plumbing 0 05-14-2011 08:50 AM
Expansion tank location?? rcassidy HVAC 4 10-06-2009 09:01 AM
Hot water heater expansion tank? rjniles Plumbing 3 06-21-2008 10:53 AM
