Is There A Temporary Fix For A Tiny Hole In Cast Iron Sewer Line? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree13Likes
Old 08-22-2017, 02:13 AM   #16
Rewards Points: 26
Re: Is there a temporary fix for a tiny hole in cast iron sewer line?
Hi. I'm new here. I had almost the same problem in my residential rental, except mine was a crack running through the joint. Solved it with a wide self-fusing tape, wrapped several times. It's been there 3+ years, even though it was supposed to be temporary!
I can't post a link since I'm new here, but if you search for self-fusing plumbers tape you will find what I'm referring to. It's been part of my home repair stuff ever since.
HTH Denise
fischdf is offline   Reply With Quote
The Following User Says Thank You to fischdf For This Useful Post:
jeffmattero76 (08-22-2017)
Old 08-22-2017, 06:48 AM   #17
Rewards Points: 18
HTH Denise
Thanks! I actually went to the orange big box yesterday and the guy in tje plumbing aisle showed me that product, which i had never seen before. I bought a roll of it, and a stick of JB Weld. I plan to trythe JB Weld first, but if that doesnt hold, I plan on using that tape. Thanks again for the tip.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 08-22-2017, 10:21 AM   #18
Rewards Points: 1,492
Also a wire brush that looks like a toothbrush for tight space. Brush off rust and paint. Citrus grease remover for any oil on the cast iron. Disposable gloves for working with epoxy. Use your hand to push first layer of thin epoxy over the repair area for good adhesion. Then second thicker layer. Cast iron crack can continue to open up but this kind of repair could last as well. Wait couple of hours to make sure JB weld is cured. I did have uncuring jbweld.
carpdad is offline   Reply With Quote
Old 08-22-2017, 03:33 PM   #19
retired framer
Rewards Points: 15,222
Do we really think this pipe won't spring another leak a week after this one is stopped
Is there any consideration on just changing it out?
Old 08-23-2017, 07:32 AM   #20
Rewards Points: 18
Neal - i am definitely planning on changing it out, but there is a tenant in the property who is moving shortly. Once they move, I will have my plumber replace it with PVC. I am looking for a temporary solution to hold me over until they move out.
Nealtw likes this.
Sewer drain overflows, possible main sewer line collapse Photog0411 Plumbing 7 07-29-2016 09:06 AM
NEED ADVICE: Mystery water near sewer line tripower Plumbing 9 10-22-2013 11:31 AM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
rubber gasket donut for cast iron sewer pipe to pvc jbitt Plumbing 6 04-25-2010 12:29 PM
Replacement sink with cast iron model Mike in Arkansas Plumbing 5 02-14-2010 08:12 AM
