Teaching Myself To Sweat Copper Pipe... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree18Likes
Old 03-17-2017, 01:29 PM   #1
donste2010's Avatar
Rewards Points: 152
Question
Teaching myself to sweat copper pipe...
Hi all,
Well I have the bathroom reno happening and I want to do all the demo myself. I need to cap some pipes of course, and I will teach myself to sweat copper pipe (I've seen it on TV many times lol). When I cut the copper pipe with a pipe cutter, it leaves a little ridge on there, effectively making the ID smaller, is there a certain tool to (I think) deburr the ID? As you can tell I have not tried anything yet...
Thanks!
donste2010 is offline   Reply With Quote
Old 03-17-2017, 01:57 PM   #2
Super Moderator
Gymschu's Avatar
Rewards Points: 556
Re: Teaching myself to sweat copper pipe...
Reamers, DeBurring tools is what I've called them. I wish you the best and let me add that I have the utmost respect for the plumbing trade after my feeble attempts at soldering. Although I'm decent enough, my joints never look as neat and it takes me several attempts to get it right. And, yes, the frustration when you have leaks is 2nd to none. Practice, practice, practice.
jlhaslip and donste2010 like this.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 03-17-2017, 02:19 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 248
One of these or the built in reamer on a good pair of cutters
http://www.homedepot.com/p/HDX-Debur...X090/204218603
donste2010 and Yodaman like this.
Old 03-17-2017, 02:21 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,936
A lot of the copper tubing cutters have the reamer attached. It's steel pointed bit that swings out.
donste2010 likes this.
Old 03-17-2017, 02:45 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,224
I prefer the reamer (that sounds bad) to the deburring tool.
Cleanliness is close to Godliness when it comes to sweating pipes. The cleaner they are, the easier it it.
Old 03-17-2017, 03:22 PM   #6
Breakin' Stuff
Rewards Points: 1,374
I got real fancy and used a pair of pliers. Pushed them in the end of the pipe and twisted.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Old 03-17-2017, 07:40 PM   #7
Any reason not to use push fittings and pex? Way easier, especially if sweating in a confined spot
Sent from my SM-G935V using Tapatalk
chris35moto is offline   Reply With Quote
Old 03-17-2017, 08:03 PM   #8
Property Mgt/Maint
Rewards Points: 8,202
Yep, sometimes. Most try to avoid putting sharkbits in enclosed spaces like wall cavities and floor to ceiling spaces. The long term confidence level isn't there yet.
Converting to pex still requires sweating on a adapter.
Yodaman is offline   Reply With Quote
Old 03-17-2017, 08:23 PM   #9
Are shark bites known to fail? I tiled over 3 push fittings... hopefully mine don't burst lol
Old 03-17-2017, 08:38 PM   #10
Property Mgt/Maint
Not necessarily. I have installed dozens of them, and as far as I know all are still in service. Not trying to scare anyone. Am just not 100% confident in the long term durability.
MTN REMODEL LLC likes this.
Old 03-17-2017, 09:23 PM   #11
Rewards Points: 6,334
Once these techniques are learned soldering tubing is a snap. It gets more challenging when a second joint needs to be soldered without melting the first in close proximity. That's when the 15 differential melting temperature of the second solder joint plays a major role.
Soldering can be fun.
Old 03-23-2017, 01:33 PM   #12
donste2010's Avatar
Rewards Points: 152
Question
Thanks guys!
OK another question, some of the first caps I have to put on are near a length of PVC pip, what is the best way to shield the PVC and keep it from melting?
Old 03-23-2017, 01:41 PM   #13
A few wraps of a wet cotton rag wrapped around the PVC and cover that with aluminum foil will probably do it.
abrowning and donste2010 like this.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
abrowning (03-23-2017)
Old 03-23-2017, 03:58 PM   #14
Rewards Points: 44
I use a piece of 3/8" plywood behind the piece being sweated to take the heat. I also have a 6"x9" flexible shield that can squeeze into tight places to handle the flame. It has eyelets so you can drive a screw and hang it in place.
Always have a spray bottle of water handy when sweating in a wall. My brother in law burned half his second floor down sweating a pipe in a stud bay. He hadn't taken any precautions and had no water handy.
In my locale shark bites are not to be placed in inaccessible areas. I've had good luck sweating on a pex adapter to which I attach the pex with a crimp ring. You can seal that in a wall. If you do enough of them it's cheaper than shark bites.
SeniorSitizen likes this.
abrowning is offline   Reply With Quote
Old 03-23-2017, 06:29 PM   #15
Property Mgt/Maint
Originally Posted by donste2010 View Post
Thanks guys!
I use drywall scraps. The paper will turn black but drywall doesn't burn very well.
abrowning likes this.
soldering copper pipe stubs next to drywall Adam_Reith Plumbing 12 03-30-2017 04:48 PM
Copper pipe grounding adgjqetuo Electrical 9 04-05-2016 08:42 AM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 07:48 AM
