Tapping Into Hot Water Line For Hot Water In Garage - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2015, 04:58 AM   #1
Tapping into hot water line for hot water in garage
I am interested in tapping into the hot water line coming from the hot water heater. Is this a good idea? I plan to sweat copper piping and was just wondering if any suggestions could get tossed around here to help. I've never done this before, but doesn't look to hard and I want to save money.
Mrhandymanjoe is offline   Reply With Quote
Old 03-20-2015, 07:11 AM   #2
Rewards Points: 320
I'm assuming you're putting in a wash up sink? Will you need a drain as well? Cold water? If you've never sweated copper before there are easier methods, although sweating is one of the cheapest ways once you learn how.
Depending on your location this may not be a feasible idea due to the possibility of freezing.
daveb1 is offline   Reply With Quote
Old 03-20-2015, 07:23 AM   #3
Rewards Points: 1,602
If freezing is an issue you're going to want to put a shut off valve inside so that you can cut the water during the colder times. My garage doesn't get below freezing even when it's zero F outside so it may not be an issue for you.
mikegp is offline   Reply With Quote
Old 03-20-2015, 07:26 AM   #4
Rewards Points: 3,130
If you're never sweated copper pipe, I suggest you practice a bit first. It isn't difficult, but something simple like not properly cleaning the pipe will result in a poor connection. You'll probably have to shut off water to the whole house, so you want the job done quickly and right the first time.
Old 03-20-2015, 09:14 AM   #5
Rewards Points: 18,988
Live in an area where it may freeze?
Is the garage heated all the time?
Old 03-20-2015, 12:18 PM   #6
Rewards Points: 781
Run it in pex.
ct18 is offline   Reply With Quote
Old 03-20-2015, 05:04 PM   #7
Rewards Points: 10,814
Shut off the water of course. And let it all drain out before starting. Open other taps in the house so air can flow. You will have a very hard time soldering the pipes if water keeps dripping in as you are trying to solder. Depending on how pipes are laid out, sometimes I have had to wait 20 minutes before all the water stopped dripping.
SPS-1 is online now   Reply With Quote
Old 03-20-2015, 05:42 PM   #8
Rewards Points: 6,518
If possible, make as many solder joints as you can in the shop and only one to do the final connection that may be in an awkward location.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Tapping into main water line racinpig Plumbing 3 07-31-2012 11:53 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
tapping water line for new line KarlJay Plumbing 5 07-28-2010 09:30 AM
Tapping into water line Dave8 Plumbing 6 02-23-2009 08:26 PM
