Tank -> Demand Heater Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2016, 10:01 AM   #1
Rewards Points: 2
Hi there,
I'm planning on replacing my 75 gallon NG tank with a demand heater installation. I've ordered a Takagi T-H3-DV-N. I have a couple of questions:
1) Is there anything that would prevent me from re-using the exhaust of the existing water heater? The Takagi installation manual shows various rooftop vent installation options; I would like to take advantage of the existing rooftop vent, if possible.
2) I recently had a new furnace installed with has dedicated inlet outlet vents. I plan on having the direct vents installed on this demand heater as well (to take advantage of added efficient of using outside air for the input. I've noticed I have this fresh air vent that just passes in outside air into the general furnace/hot water tank area...it is just spilling in cold air. I believe I have rendered this vent obsolete by installing this demand heater...is that true?
Thanks,
Ryan
rjking2112 is offline   Reply With Quote
Old 02-09-2016, 12:49 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
dont use the vent through the roof with the existing flue pipe, the old heater was natural draft, the new takagi is induced draft and uses special vent pipe, if you pipe in fresh air into the takagi from outside you can close up tho old fesh air into the room..as the new furnace you put in also has fresh air piped into it..
WhatRnsdownhill is offline   Reply With Quote
Old 02-09-2016, 03:39 PM   #3
Rewards Points: 1,852
Venting with Schedule 40 PVC, CPVC, PP, Category III stainless steel
Listed under the specs.
http://www.takagi.com/products/tankl...ters/t-h3-dv-n
You may need to resize your gas line Maximum BTUs: 199,000
This is a direct vent unit. Out through the side of the house in scd 40 solid core PVC pipe.. NO FOAM CORE ALLOWED NO ABS ALLOWED.
Product manual:
http://www.takagi.com/media/54108/68A161.pdf
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Question re draining heating expansion tank Rav HVAC 4 11-19-2012 09:53 AM
Removing anti-siphon valve from a toilet tank Chris0516 Plumbing 7 09-30-2012 05:09 PM
Sewage extraction tank installation. CDN007 Plumbing 2 01-15-2009 05:00 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
