Tahoe Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2015, 03:41 AM   #1
Rewards Points: 8
tahoe water softener
suck at backwash, dial reads 001 , and it has now been 1 hr since it woke us up
inneedof is offline   Reply With Quote
Old 05-02-2015, 05:03 AM   #2
Rewards Points: 3,496
What does the owners manual say about that error code? Start there.
You're in luck, there are a couple water treatment techs that frequent this forum, please wait for one of them to respond. Thanks.
jmon is online now   Reply With Quote
Old 05-02-2015, 05:16 AM   #3
Rewards Points: 8
I checked and there is no error code the screen shows 001 and the only one in the book is 1001 a different number. Thanks for getting back to me....
The Following User Says Thank You to inneedof For This Useful Post:
jmon (05-02-2015)
Old 05-02-2015, 06:37 AM   #4
In your manual, does it have anything about running a diagnostic test to test all components of the water softener as you observe it?
Most have some sort of self-testing feature which can help diagnose the problem. Try to determine which component is failing.
The Following User Says Thank You to jmon For This Useful Post:
inneedof (05-02-2015)
Old 05-02-2015, 06:58 AM   #5
Rewards Points: 8
I will see what I can find on line, the manual is not very clear on a lot of things. See your rep is the common response. Typical come back I guess, JOB SECUIRTY LOL!!!
jmon (05-02-2015)
Old 05-03-2015, 11:59 AM   #6
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Using one of the Clack valves, that is if I pulled the correct information.
Did not see a 001 but did find a 1001 error code...in that it could not recognize start of regeneration.
Was there any kind of work done to the system?
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
inneedof (05-03-2015)
Old 05-03-2015, 01:49 PM   #7
Rewards Points: 8
water softener
I did a complete reset and then followed the book. Maybe there was some small piece of grit in the screw..so far so good.
Thanks guys for all the advice.
Old 05-03-2015, 01:53 PM   #8
Water Treatment
Akpsdvan's Avatar
Question still standing, was there work on the system?
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water Softeners rickglarson Plumbing 1 01-09-2012 04:10 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
