Swaging Tool Help - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By Ghostmaker
Old 10-19-2016, 06:13 PM   #1
Rewards Points: 1,228
Swaging tool help
Hi. I purchased an IWIS swaging tool; to me it looks similar to Hilmor's 1839015. I'm attempting to swage type M 1/2" copper. Using the 1/2" adapter it bottoms out before I can even detect a noticeable expansion. By bottom out I mean I'm having to use two hands and it looks to me the adapter reaches the end of its travel. Just for curiosity I toyed with the 5/8" adapter, which splits the tubing early-on into the swage. Any ideas on what I'm doing wrong? Thanks.
bfletcher7 is offline   Reply With Quote
Old 10-20-2016, 12:00 AM   #2
Rewards Points: 80
Re: Swaging tool help
If it split the copper, it means that it was hard drawn copper. All fittings will be hard drawn. They must be anealed first.
If you mean one of these, then you must use the right sized tip.
https://images-na.ssl-images-amazon....-L._SY300_.jpg
If you mean one of these then the clamp has to be tight enough.
https://ae01.alicdn.com/kf/HTB1LMApL...ing-b-font.jpg
Cheers!
supers05 is offline   Reply With Quote
Old 10-20-2016, 04:22 AM   #3
Thanks. It is the hydraulic tool. I will anneal it first and retry.
Old 10-20-2016, 06:00 PM   #4
Rewards Points: 1,950
You need to use soft copper That is type L or K. M is a hard copper
SHR Plumber and supers05 like this.
The Following User Says Thank You to Ghostmaker For This Useful Post:
SHR Plumber (10-21-2016)
Old 10-20-2016, 10:09 PM   #5
Originally Posted by Ghostmaker View Post
M is a hard copper
Appreciate the feedback.
power tool safety tips ec0warrior Safety 4 12-21-2016 04:01 AM
Swaging Tool for Plumbing coper digitalplumber Plumbing 6 06-25-2014 09:04 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
