Surge Tank Or Press. Relief Valve Fail? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2016, 09:57 PM   #31
Rewards Points: 3,230
With a 75 gallon tank you're really close to the 80 gallon change over. It Probably wouldn't hurt anything using the smaller one, but for safety, I would use with the bigger 5 gallon expansion tank if it were me. Just my thoughts.
Whether it's 2 or 5 gallon, as you have mentioned, they can very heavy when full of water, so make sure it's supported properly.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
kree (01-07-2016)
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Relief valve leaking mreber Plumbing 21 10-01-2013 05:08 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Replacing a Pressure Relief Valve for a Boiler multiphrenic HVAC 18 11-30-2011 11:16 AM
