Support For Shower Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 04-04-2017, 05:30 AM   #1
Rewards Points: 294
Support for shower valve?
How can i support a shower valve when i replace it. The old one is screwed into a 1by, but I will have to take this out and only have access from the rear.
Mikeron is offline   Reply With Quote
Old 04-04-2017, 06:11 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,368
Re: Support for shower valve?
You can always screw into the mounting holes on the valve with some machine thread screws and screw in from the back. You could pre drill the support wood, mount some studs to the valve, and put some nuts on the back of the board and clamp it down that way as well.
Mikeron likes this.
Install hanger to support water pipe and valve for water heater HomeLearner Appliances 24 11-12-2014 02:07 PM
Install Angle Gas Valve Upside-Down? fritzycat1 Plumbing 6 03-23-2014 02:29 AM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
