Sump Spraying Water From Base While Pumping - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2017, 09:57 AM   #1
Rewards Points: 224
Hello. I order a sump pump kit online. I followed the instructions. The pump is cast iron. I filled the basin up with water to test it out. It pumps out water fine but I noticed water is spraying from the base (where the base is bolted to the main pump). I would assume there would be a seal there and it would only leak if there is to much pressure?
Never had a sump pump before not sure if this is normal or not. It is pumping water to the outside fine. Just want to make sure before the return policy expires.
I have the sump pump on bricks inside the basin. I have the check valve coming off the sump pump then to the discharge drainage....
ryanb4614 is offline   Reply With Quote
Old 09-23-2017, 01:39 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,324
Re: Sump Spraying Water From Base While Pumping
Ayuh,... The pump is fine, they're not sealed units,...
Sump Pump Running Constantly - Never Ending Water! seldom Plumbing 7 12-08-2015 07:59 AM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Brand new water heater TPR valve spraying fetzer85 Plumbing 50 03-20-2013 11:32 PM
Yet another sump pump / pit question SeanFlynn Plumbing 0 01-24-2010 01:07 PM
sump pump water lower than normal???? fabian Building & Construction 18 12-05-2009 05:26 AM
