Sump Pump Stuck On All Night - Replace Or Fix Switch? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-18-2016, 01:18 PM   #1
Rewards Points: 34
Sump pump stuck on all night - replace or fix switch?
Got up this morning and heard a hum from basement. Zoeller 53D stuck on pumping no water. Unit was warm, plug was warm. Float no effect. Likely switch failure. Was just going to replace the switch but 2 things bugging me:
  1. With it being left on and running hot for undetermined period of time, possibly damaged or other components?
  2. Inside switch housing obvious signs of some water and corrosion. See pic below.
a_gunslinger is offline   Reply With Quote
Old 12-18-2016, 02:18 PM   #2
Rewards Points: 3,404
Re: Sump pump stuck on all night - replace or fix switch?
I suggest replacing the float switches. If you try to repair the switches they will be a constant worry that they might fail again.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 12-18-2016, 02:26 PM   #3
Rewards Points: 34
Thanks for the reply. I would definitely replace the switch, not try to repair. I guess my main question is whether being stuck on for a long period and getting hot for a long time is likely to have damaged another component. And while the new switch will likely fix stuck on problem, having run hot uncooled for that long is other failure possible? It was very warm to the touch.
Old 12-18-2016, 02:36 PM   #4
Rewards Points: 34
Title wasnt clear: should I "Replace Pump or just the switch"?
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump Pump/ French Drain Advice jackislost Landscaping & Lawn Care 7 06-21-2015 09:23 PM
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 01:55 PM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
