Sump Pump Outside - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2015, 11:32 AM   #1
Rewards Points: 4
Sump pump outside
I bought a house that has a terrible yard flooding problem. I want to put a sump pump in the backyard. Is it ok to leave the pump outside during the winter. I want to install it and leave it there permanently. Can freezing weather damage the pump? Should I disconnect it for the winter?
Tkoval is offline   Reply With Quote
Old 04-24-2015, 11:59 AM   #2
Rewards Points: 3,476
Not a good idea to leave it outside permantely during the winter imo. Can you address the issue with drainage weeping and route water away?
If you do use a sump pump, set it up with quick disconnects and bring pump inside during the winter. Just a suggestion.
Others will be along with more advice/suggestions.
jmon is offline   Reply With Quote
Old 04-24-2015, 01:57 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,266
Ayuh,.... A sump pump is the worst possible fix for any outdoor water control,....
Either surface or sub-grade drainage is the only Real answer,....
'n, Yes, freezin' a sump pump with water in it will kill it,...
Where ya gonna pump the water too,..??
Old 04-24-2015, 04:05 PM   #4
Rewards Points: 1,948
French drains are they way.
Sump Pump Backup System steve-19 Plumbing 1 01-18-2013 12:15 PM
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 01:55 PM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
