Is A Sump Pump Mandatory? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By jomama45
Old 04-12-2017, 05:44 PM   #1
Rewards Points: 26
Is a sump pump mandatory?
I'm working at the plumbing layout for our house and because we are building on the hill I'm wondering if a sump pump in the sump basin is mandatory. I can layout the pipes for a gravity drain of the basin but not sure if this is this accepted by the code?
Thanks for any advice.
rogerius is offline   Reply With Quote
Old 04-12-2017, 05:50 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,218
Re: Is a sump pump mandatory?
If the water can be routed to drain out via gravity, I don't know what the requirement would be for forced ejection except as a back up and routed out via a different pathway in case the gravity drain ever becomes obstructed.
Old 04-12-2017, 05:56 PM   #3
Rewards Points: 26
..but the same concern can be applied if a pump exist; the outlet also can be obstructed..no?
In any case with or without pump I'm planning to route the outlet down the hill as I consider as clean water no waste. Does somebody know if is any regulation about this, as example to to build a basin for natural drain?
Thanks for the quick reply.
Old 04-12-2017, 06:03 PM   #4
Less likely to be obstructed via the ejection and emptying on the ground vs. sub ground level.
Old 04-12-2017, 06:12 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 31,928
It could be a local code to have one.
However if it is not code to have one, then I would not even install a sump pit. I would simply let the line drain by gravity.
Old 04-12-2017, 07:05 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 248
If you're talking strictly storm water, then I doubt most plumbing codes cover it except to say that you don't pipe it to the sewer/septic.
Best to check with your bldg. dept.
Old 04-12-2017, 07:06 PM   #7
Usually Confused
lenaitch's Avatar
Rewards Points: 2,030
Agree that it might be required by local code, even if practically not required. We had a house in a small city with a bone-dry sump and the cord from the pump didn't even reach the receptacle. Same for the outlet - may or may not be governed by a local rule. Provincial/State and local building codes are often driven by caution from past events, '100 year weather event' liability, etc.
lenaitch is offline   Reply With Quote
Old 04-12-2017, 08:25 PM   #8
Concrete & Masonry
Rewards Points: 516
First, you have to understand that there is no building code that covers the entire universe that this site reaches, not even one uniform code for the US. W/o listing at least a state that you reside in, there not much actual help anyone can offer.
That said, where I live and work, the great state of Wisconsin, OUR building code states that every dwelling needs a sump basin/crock, and pumps are optional........
Windows on Wash likes this.
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
kwikfishron (04-12-2017)
Sump Pump/ French Drain Advice jackislost Landscaping & Lawn Care 7 06-21-2015 09:23 PM
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 01:55 PM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
