Sump Pump Discharge Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By JRMN
Old 11-26-2016, 10:55 PM   #1
Rewards Points: 117
Today I had to repair my sump pump discharge pipe. I don't know what the grey stuff was that removed. My house was built in the late 80's and has aluminum siding. Can someone recommend what I should use to seal the area around the PVC pipe on the exterior of my house? Thanks in advance.
JRMN is offline   Reply With Quote
Old 11-27-2016, 07:26 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,444
Re: Sump Pump Discharge Pipe
Available at all the big box stores.
http://www.homedepot.com/p/Gardner-B...-110/100212441
Old 11-27-2016, 09:58 AM   #3
Rewards Points: 117
Thanks. I'm headed out to go pick some up from the store. Here is a photo. I need to figure out how to remove the remainng residue.
Old 11-27-2016, 10:17 AM   #4
Be wary of anything too strong. It will strip the paint right off that siding. I would start with something like Goo Gone.
Old 11-27-2016, 05:19 PM   #5
Rewards Points: 117
Ok guys, I tried goo gone. It didn't work nor did scraping it. You all think it would be safe to just go over it with the duct seal?
Old 11-27-2016, 05:59 PM   #6
Rewards Points: 3,222
Imo, Yes. You can always paint it so it's not so noticeable.
jmon is online now   Reply With Quote
Old 11-27-2016, 06:18 PM   #7
Rewards Points: 117
I'm confused. I'm talking about leaving what's left of the old putty and just going over the putty with new putty.
Old 11-27-2016, 06:51 PM   #8
So am I. You got what you could off. I don't see any problems with adding new putty. It will bond with the old. Then paint if needed. Just a suggestion and my opinion only.
Others may not agree with me.
Old 11-27-2016, 06:59 PM   #9
Rewards Points: 117
Oh I see now. Sorry for the silly questions. I work I an office and have limited knowledge these things. I hadn't considered the new color versus the old. My question was more abound bonding than anything else.
jmon likes this.
Sump pump check valve, on pump or spliced in pipe? ponch37300 Plumbing 1 06-18-2016 12:26 PM
Sump pump poly pipe mikemark8808 Plumbing 6 01-17-2016 09:09 AM
Sump pump discharge question Freedomsand Plumbing 18 03-25-2015 07:31 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 08:32 PM
