Sump Pump Discharge - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2017, 10:12 PM   #1
Sump pump discharge
Im stumped on the best way to discharge my sump pump. I cant go to the street because of an easement or through my yard because theres an alley with poor drainage.
Im by chicago (brookfield) and the line will freeze in winter so im planning to bury french drain pipe surrounded by gravel.
I added a basic drawing of my yard and what i was planning. The red line would be a 4" corragated drain pipe to a gravel pit(garbage can with holes and gravel)under a small deck.
My yard does get flooded spots in heavy rain and im worried it may not be able to drain when the ground is saturated or cold.
Im pretty handy but ive never did anything with outdoor drainage.
Any help or opinions greatly appreciated
Cainhawk is offline   Reply With Quote
Old 07-24-2017, 10:21 PM   #2
retired framer
Rewards Points: 15,482
Re: Sump pump discharge
A perk test is done to see how fast water will be absorbed
Old 07-25-2017, 08:33 AM   #3
Thank you ill have to try that next rain i get.
Im not really sure if this is the correct way to run the line outside though either
Sump Pump Discharge blizzard5 Plumbing 4 10-30-2015 06:01 PM
Sump Pump Discharge - Below grade good or bad? ricksample12 Painting 1 06-24-2015 11:51 AM
Sump pump discharge Mark Harvey General DIY Discussions 3 05-31-2014 12:30 PM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
